Question about HP Photosmart D7260 Printer
HP D7260 can't print color in black & white only - greenish hue
I am trying to print color pictures in black and white. I set printer setup to gray scale and the pictures do come out in b & w but with a distinct greenish hue. I want to use the black cartridge only. How do I do this?
  • Anna Campbell Jan 05, 2013
    change printer settings to grayscale AND below that put dot in optimize for photocopy or fax. Be sure to set printing quality to at least normal.
I am having the same problem, printing photos I took of the moon thru my telescope. Any solutions?
Posted on Aug 01, 2010
How to make HP C6380 print black & white only
You should be able to go into your printer preferences or properties settings by going to the "Printers & Devices" tab. If this is for Widows 8 or 8.1 I have not upgraded to either OS and have no clue as to their layout for access. In XP and 7 there is the option of changing your default settings from color/auto to black & white only. Make sure you hit the "APPLY" button to set it "OK" button doesn't always keep the settings locked in.
Nov 04, 2014 | HP Photosmart C6380 All-In-One InkJet...
How to set hp color laserjet cm 1017 mfp to print black and white
Open the Printers Properties, settings, select your print preference.
Jan 01, 2013 | HP Color LaserJet 2600n Printer
Want to print black and white. How?
Setting the font type color in a Microsoft Office Word document to black will ensure that the document prints the text in black. However, if there are images, graphics or photographs within the document, they will more than likely print in color or hued colors similar to black. To ensure that the entire document prints solely in black ink, you must set the color settings on your individual printer to black-and-white
Instructions:
1.Click "File" and then "Print." To open the print dialogue box using keyboard commands, press "CTRL" and "P" simultaneously.
2.Select the printer you are using at the top of the dialogue box under "Printer" and "Name."
3.Click the "Properties" button next to the selected printer. The dialogue box that appears is different for all users, as it depends on the type of printer being used.
4.Click on a tab, button or selection box indicating "Color." Most options include high-quality color, grayscale and black cartridge only. Choosing grayscale will print the document using various shades of gray and other tones such as blue or green that match the actual hues in the document visible on the screen. A photo or picture that may look black or gray could actually have blue undertones. To print purely in black and white with no undertones, you must select either "black cartridge" or "black and white only."
5.Select "OK" to return to the Microsoft Word printer dialogue box. Press the "Print" button to print the black-and-white document.
I hope you find it very helpful. Thanks.
Aug 25, 2011 | Computers & Internet
How do I get my photosmart D7260 to print black and white only? I have changed the settngs to grayscale only using the black ink cartridge, but I continue to receive color prints.
Hello Shaw ,
When setting to grayscale , click on the " High Quality " arrow and select " black ink only " .
Best regards ,
fanaudi .
May 10, 2011 | HP Photosmart D7260 Printer
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
Printing black and white photos from digitally taken colour photos
Hi Pat,
First you will have to check the Nozzle of your printer. To do this, press the setup button and select Nozzle Check. Use a plain paper to do this. Press Ok after that. It will print out a pattern for each color. Make sure that the lines are connected to each other specially for black since that you are printing a black and white photo. Lines going across is on a stair case pattern and should be connected to each other. Proceed with cleaning cycle if needed.
You can do a cleaning cycle using your printer of the computer. You can skip this if you have a good Nozzle check.
Using printer:
Press setup then select head cleaning.
Using computer.
Go to utility of the printer and find maintenance. Click on the head cleaning button.
Once that the nozzle are fine, you can now try printing. I strongly suggest that you use other application first instead of Adobe Photoshop. Since that Photoshop uses color management, it can be that the settings are incorrect. Save first the picture that you opened in Photoshop. You can save it on your desktop to easily locate the file. Make sure that the file is in jpeg format. Now to isolate the issue if it is cause by a software or not, try the standard application for your O.S.
Smaple Application:
Windows O.S. : Windows Picture and Fa Viewer
- right click on the file and select open with.
- select windows picture and fax viewer.
- folow the on screen instuctions.
Note: If you are now on the window on what pinter to use. Make sure that you set the option for printers under preferences to print in gray scale or black only. Select also the correct paper type.
- Proceed with printing.
Mac OSX: Preview or Iphoto
- open the picture under one of the application.
- click file then print.
- Make sure printer is selected.
- underneath the print option, you will have to go to print setting.
- find the option that says color then select black.
- select the appropriate settings for paper.
- the click on print.
Now see if it did print out corectly. If it did, it means that the appplication is the one causing this. If you are familiar with the color manage features of the application Photoshop. Let Photoshop handles the color. After getting to the widow what printer to use, to the the preferences of the printer and select the correct paper type. You will have to find the color management of the printer.
For Windows, It under the advance option under the main tab. Select off no color adjustment.
For Mac instead of going to print setting, find color manage and turn it off. Select off no color adjustment.
Then try printing.
Regarding your other question, If the printer is producing excess inks on your print out when ot comes to black printing and color printing, that pad needs replacement.
Aug 15, 2008 | Epson Stylus Photo RX700 All-In-One InkJet...
Black does not print well
Try priting a test page to identify the color in questions.
http://www2.clicshop.com/Stores/metawatch2/Files/metawatchprintertestpage.pdf
Chances are you are running out of another color...
In reality the printers actually use other colors to print black, besides the black ink. (I.E. if its a picture etc...)
A greenish hue normally means your Magenta is running low.
http://en.wikipedia.org/wiki/CMYK_color_model
Feb 09, 2008 | Epson Stylus CX6400 All-In-One InkJet...
HP Photosmart D7260 Printer Logo
513 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
