Home | Hotpoint | 24 in. HDA3400G Built-in Dishwasher | Not draining
Hotpoint 24 in. HDA3400G Built-in Dishwasher
Problem for Hotpoint 24 in. HDA3400G Built-in Dishwasher
Not draining
By barracats on Jul 01, 2009
my dishwasher is running partly...but stopping b/c theremust be a clog...the bottom is filling up with water and staying.....what tools do i need?
Comments:
Jul 19, 2009
- thank you. my filter was clogged....had broken a wine glass, and couldnt find the rest of the glass. the rest was in the filter. will wash by hand from now on! thank u!
Best Solution
posted on Jul 01, 2009
Helpful)
Maytag317
Rank: Guru
Rating: 93%, 650 votes
Hi, Tools you might need are, 1/4" & 5/16" nut driver/socket, phillips screw driver & pliers.
I would remove the drain hose from the sink and put the end into a bucket. Start the d/w into spin and see if water releases.
If it does, clesn out the sink port the hose connects to.
If the d/w does not drain, remove the lower front panel and locate the drain solenoid. With the d/w running, turn the timer/selector knob and see if the solenoid engages at the end of each cycle. If it does engage, the drain hose or the sump inside the d/w must be plugged.
If it does not engage, you will need to put a voltage meter in the wire connection on the solenoid and repeat the proccess with the turning the timer and see if the solenoid is getting 120V at any time.
If this is draining into a garbage disposal and you have replaces the disposal, make sure the plug inside where the drain hose hooks up has been removed. I see this quite often.
I hope this helps you. Please let me know if I can assist you further.
Vic
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Hotpoint 24 in. HDA3400G
Questions and Unsolved Problems for Hotpoint 24 in. HDA3400G
Do you recommend Hotpoint 24 in. HDA3400G Built-in Dishwasher?
Answer
Answer
My dishwasher does not drain. I've pulled off the main top screen. What next? How do I pull off the... (More)
Answer
Machine went through first light wash and then stops on the second light(spray) and beeps and won't... (More)
Answer
The top section of the wash tower came out. How do I put it back in?
Answer
washer fills with water but will not click on once the wash cycle starts
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hotpoint 24 in. HDA3400G...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
