Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Intex 8110 won't unlock just get continuous beeping
4 Suggested Answers
  • 351 Answers
SOURCE: This is my 3rd year using intex 8110 sytem. I
That code means the unit is in standby. It should start working if you set the opperational hours that you want in the program. Use the program guide in the manual.
Please Vote !!
Posted on Jun 02, 2010
SOURCE: No power on 8110 Intex Saltwater System
I have the same issue. Three years old so please do not say to send it in. Can you buy a replacement power supply?
Posted on Jun 16, 2010
briones93
  • 119 Answers
SOURCE: I have a salt water
Okay... Let's do this step by step...
1st... Press the down arrow button until you hear the beep and let it go quickly..
2nd ..Press the up arrow button until you hear the beep and let go quickly..
At this point, the LED reading should be blinking 00.. If it is, you have unlocked the keys and you can now press the up arrow button to increase the timer to 01, 02 and up to 12. Note: To adjust the time, press the up arrow button in short intervals, do not hold down the button. It tends not to adjust if you hold down the button longer than 1 sec.. I hope this helps and it not a bad unit.. If it did, please post a comment and rate.. really appreciated...
Posted on Aug 09, 2011
I have a salt water pump 8110. It won't go pass start up and when I push the left button it just keeps beeping. It will not let me unlock the keys to set timer. I have already unplugged for 10mins....
Aug 08, 2011 | Intex Automatic Salt Water System for ...
Have no owners manual and can't figure out how to set the timer!
code 88
Is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process
If you need the manual you can email Intex at www.email.intexstore.com
Or you can buy the manual on this link below.
http://home-and-garden.become.com/intex-krystal-clear-deluxe-saltwater-system-salt-in-pool-model-8110-owners-manual--compare-prices--sc906782580
Good Luck and please rate 4 thumbs up for the free answer.
Jul 05, 2010 | Intex Automatic Salt Water System for ...
When I try to set the time on my intex 8110 I can set the time & when I leave it for 10 minutes it always goes to flashing 94. Is there something wrong with the pump or maybe it's possible I'm missing...
that sounds really weird. There is no code 94
Try locking it manualy
hold down arrow till beep
now hold up arroe till beep
now with quick pushes set desired hours of run with up arrow
now hold till beep on down arrow then hold down on up arrow till beep
the unit is now locked and should start it could take upwards of 10 minutes
If all else fails you can call intex with a valid receipt up to 2 years of purchase and they will replace it
Hope this helps
Jun 21, 2010 | Intex Automatic Salt Water System for ...
Jun 14, 2010 | Intex Automatic Salt Water System for ...
Please Vote !!
Jun 01, 2010 | Intex Automatic Salt Water System for ...
Code 88
Plug the pump in. You will see code 88 which is normal. Press and hold the down button for 2 seconds until you hear a short beep.Then press and hold the up button for anohter 2 seconds until you hear a short beep and the LED flashes 00. Using the up button set the time to run based on the size of the pool which you did not list. Tell me the size and I will tell you how many hours to set on the timer. You can download an owner's manual here: http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143
Saltware system from intex won't unlock
I'm not sure exactly what buttons you're pushing but you push the down button until it beeps, then the up button until it beeps. Then you set it. To lock it you push the down button until it beeps, then the up button until it beeps. Hope that helps and I apologize if those are the steps you're already taking.
May 27, 2010 | Intex Automatic Salt Water System for ...
How do you set the panel on a salt water intex pump mdl no.8110 and how much salt do use
to set the system, hold the down button until it beeps, then hold the up button until it beeps. Now the system is ready to set. Push the up button to the desired number of hours you want it to run. Now, hold the down button until it beeps, then the up button until it beeps. It should be locked and ready to start working.
Without knowing how large your pool is, I can't give you an exact amount of salt to use. If you know how many gallons your pool holds the formula is Gallons x 0.025 = pounds of salt to start up. When you need to add salt, its gallons x 0.0067 = pounds of salt to add when needed.
May 20, 2010 | Intex Automatic Salt Water System for ...
After going thru the Start up set up our Intex
After setting the time did you remember to re-lock the keypad by pressing and holding the "down arrow" for 5-seconds until you hear a long beep and then the "up arrow" for 5-seconds until you hear a long beep? Several minutes later the Green LED should come on indicating the cycle has started.
Jul 03, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
218 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
