If you remove the spark plugs it spins ok
SOURCE: engine will not make complete revolution with spark plug in
Compare the new plug with the old one, if it is longer, it may be sticking into the engine and jamming something.
SOURCE: lt1000 17 hp . problem: starter will not turn
sounds like you have a ignition switch problem.same happened to me had to replace the switch.hope this help's.
SOURCE: starter get hot engine won't start
You likely need to get the valves adjusted,it sounds like the decompressor is not working.You need to get the compression down to 130 lbs while cranking or the starter can't overcome the compression.Try turning the motor past the compression stroke by hand and see if it will crank faster,if so then the decompressor is out of adjustment.If the decompressor is not just a lob on the valves then you need to call the repair depot for craftsman and find out what you need to do to fix the problem.If none of the above works then you may need a battery,or just clean the cables and battery posts.
SOURCE: husqvarna yth2348 lawn tractor wont
It is probably having a problem with all the interlocks for the seat and brake and out of gear and such. Try moving everything a couple of times. I have had the most problems with the brake switch, but your mileage may vary.
Car not starting or turning over indicates towards multiple possibilities.
It can be issue with battery or weak battery. But if battery checks out ok, then
it can be starter issue or faulty alternator or problem with low fuel pressure or
no spark at spark plugs due to dirty spark plugs or faulty ignition
coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
