Question about Bertazzoni Gas Range
Have trouble starting the oven to preheat
We just bought our house and have this very cool Bertazzoni only problem is that it is too cool. We have a heck of a time trying to preheat the oven. The darn thing keeps shutting off or blowing out? We crack the door of the oven turn the dial to 500 push in and count to 15. (10secs does not work) It looks like it catches then it is out and we start all over again. It can take 5 times to start it, it makes me not want to use the oven. I have read somewhere that LP gas does not heat the oven very well. Would LP gas effect the starting of the oven??
thank you for any help, Linda
  • Bertazzoni Master
  • 8,220 Answers
Don't open the door(heat escapes) Turn stove wide open. There should be aboslutly no upsetting small explosions goin on at all. My first thought is the generator is weak. These systems use a pilot generator to operate the flame. If that is not it then the flame sensor itselve is wired into the mix and that is intermittant. I have no way of knowing what type of system your range uses but i can only imagine with your description. cgange the generator. that is my first thought ,it is less than the oven thermostat. the oven thermostat would be the next faulty part in the line.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 02, 2009
How to remove oven door
Bertazzoni X366GGVX Stainless Steel Gas Range Remove ...
www.fixya.com > ... > Bertazzoni X366GGVX Stainless Steel Gas Range
Bertazzoni X366GGVX Stainless Steel Gas Range"remove oven door" Questions. Question about Frigidaire Kitchen Ranges. 1 Answer ..
Aug 11, 2015 | Bertazzoni Kitchen Ranges
Why oven cools automatically after preheat
Others are having problems with this unit. Have the manufacturer support their product and fix it. It should be covered if it is new. Don't delay in hounding them. Time will expire and you will be left with an expensive ordeal.
Nov 02, 2013 | GE JKP20 Electric Single Oven
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
HEATS UP BUT TAKES 2 TIMES LONGER TO BAKE, tried cookies and cake, had to keep putting back in for longer. Did not burn, but had a weird consistency. Looked at baking coil, 'looks' fine and does get...
your bake element should get red during the preheat time and also if you leave the door open after it has preheated.
if it is not that will cause your oven to not heat right.
even if it looks ok, it could still be bad.
unplug the oven and remove the bake element, then take it to your local parts house and they can check it for you.
this is the most common problem, but it could be a problem with your oven control. try the element first.
Jan 09, 2010 | Amana ACF4225AS Electric Kitchen Range
Oven not switching on after trying to preheat
If there is not enough airflow around the oven it will turn off for safety. It will reinstate itself once it has cooled.
If this does not recover I suggest you call for a warranty service, but I am hopefiul its just the overheat sensor.
Please rate our help++++Thanks for using fixya
Oct 06, 2009 | Microwave Ovens
Lengthy preheat time
Hello. I am a Viking factory trained tech. and that is actually a normal preheat time.
Now if it undercooks that is another problem.
You may need your thermostat calibrated or replaced. If you think you are up to calibrating it yourself let me know. If it is the kind that doesn't have any white silicone in the center of the knob stem then it is quit a pain in the neck, but if it does have the silcone then it is a lot easier.
Dec 03, 2008 | Viking VESO176 Stainless Steel Electric...
Preheating
hummmm this sounds similar to what is happening to me. I am praying someone will have a solution, I don't want to have to explain to my daughter who is going to be 4 tomorrow, why I can't bake her cake.
May 12, 2008 | Ovens
REALLY long to preheat ...
I had the same problem; replace ignitor
Jan 16, 2008 | Dacor Preference PGR30SS Gas Kitchen Range
Bertazzoni  Gas Range Logo
891 people viewed this question
Top Bertazzoni Kitchen Ranges Experts
ray gallant
Anthony Kelly
Anthony Kelly
S Sigs
S Sigs
Are you a Bertazzoni Kitchen Range Expert? Answer questions, earn points and help others
