Model LA46B550K/M is cracked across the top of the screen. It shows the rest of the picture except for the outside parts where its cracked
SOURCE: tv repair
My aquos plat screen tv was pushed over by my three year old. The screen is damaged but everything esle works. Is this problem fixable?
thank you
SOURCE: broken flat screen tv
If you have not yet fixed this and haven't trashed the set I may have a solution.
I have a 50HP66 that has a good screen but bad sustain boards.
I will buy the boards from you...Easy to remove. Then you can use that money to buy a new TV.
Fixing a cracked screen is not practical. IE. Replacing the whole screen.
These sets are made to be sent to the land fill when the warranty is up.
Maybe we should have our lawmakers force companies to have minimum warranties for large toxic products that end up in the trash. Then they might make them last more than a year.
SOURCE: 32 inch Sharp Aquos Screen is cracked. Can it be
Yes, however, the Display is as much as a new set.
Testimonial: "Thank you for the information. I had a feeling that I would have to replace the set."
SOURCE: Panasonic LCD TV with cracked screen
Sorry,not repairable,because the LCD,PLasma,and DLP screen are limited produced.Replacing the tv pannel screen will cost the same as a new tv.Might even cost more after the labors.The tvs screen is about 90% of the tv,that why when is broken or damage,now it only use for it electronics boards parts,or sell for it electronics boards parts that it.
Testimonial: "thanks for the info....will have to scrap the TV for parts only. You've been helpful. Now I know what decision to make. Have a great day."
SOURCE: Only TOP half of picture shows, rest is black???
No,problems u discribing the LCD screen panel some how it shorted and dead.Replacing the LCD screen panel is not an option,because LCD screen panel are 90% of the tv,so replacing it.LCD screen panel will cost the same as a new tv,because LCD screen panel are limited produced by the tv corporations.It time to buy a new tv.
Testimonial: "thanx, i was afraid of that."
