Question about Canon FAX-L900 Plain Paper Laser
Cannot sent fax because document too long - Canon FAX-L900 Plain Paper Laser
  • 149 Answers
If you can copy the document, then you can send it BUT the receiving fax will probably have restricted length fax pages to prevent jammed documents at the sending end causing the receiver to use all the paper. If you have access to a service manual you can restrict the length of faxes sent and received on your machine. But it may be the receiver with the restriction.
Posted on Jul 07, 2009
Confirmation page needed
Press MENU - 2 4 1 then you can choose to have that feature ON or OFF. the +Image means that it will also print a copy of the first page sent so you can actually verify the document sent.
Mar 31, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Reprinting faxes already sent
Sorry, but, no...facsimilie machines have memory, however this memory is reserved for error conditions only (ie; out of paper, out of toner, out of ink, paper jam,etc.......) Unfortunately, if all faxes that were sent, were able to be recovered, it would take over a terra bite (or Tb) hard disk drive to "remember" or save these documents.....If you need the same document(s)...I would suggest that you ask the person to fax it (them) back to you.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=337&modelid=10116
Try this site for guides and further assistance. Hope this helps.
Aug 07, 2009 | Canon FAXPHONE L170 Plain Paper Laser
HOW CAN i PRINT MESSAGE FROM MEMORY FROM AN e-STUDIO 50f
Are there error messages on the display or do you want to print something that has been sent? If your fax machine needs toner/drum unit, then that will need to be replaced first. If you are looking for a document that was faxed to someone, you will need to call them and have same document faxed back to you....fax machines have memory for incoming faxes, but not for things that are "sent".
Jul 17, 2009 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
Are you able to print out a fax that was sent out approximately 6 months ago
No. Not from a fax machine. Some faxes have the ability to store sent faxes but this feature caused more problems with memory filling up than it solved. So, the machine usually deleted the job after a short period and it is extremely unlikely that your sent document is anywhere near your fax now. Not a stupid question though.
Jul 09, 2009 | Lexmark Office Equipment & Supplies
Two black lines printed on sent faxes
Clean the glass onder the cover where the document feeds in.
Apr 24, 2009 | Canon FAX-L1000 Plain Paper Laser
Fax not received
No, just the fax phone number.
Mar 09, 2009 | Ricoh 3310Le Fax Machine, FAX3310Le...
I need to get a copy of a document that I faxed.
No, the JOURNALS will only tell you the fax number it was sent to.
Feb 13, 2009 | HP LaserJet 3330 All-In-One Printer
Sending fax
If you sending the fax over the memory, fax can scann doc. while dialing, or in the same time, but if you sending directly (on-hook dial) fax is sending the document while beeing reeded.
You may try to check the phone lines, browse the documents before sending,clean the original document feed rollers,...
if fax sudenly stops and wrinkle the orig. documents there is problem in scanner area
Jan 16, 2009 | Canon FAX-JX200
BLACK VERTICLE LINE IN FAXES SENT, NOT WHEN RECEIVED?
Lift to open the document cover and use a soft cloth to clean the glass were documents are scanned.Also clean the white plate on the upper side of the scanner.You identify the scanner by observing the direction documents faces while faxing.The scanner reads the document.
Nov 20, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Canon FAX-L900 Plain Paper Laser Logo
528 people viewed this question
old marine
old marine
