Question about Brother Office Equipment & Supplies
Dirty prints Prints are getting a shading across the entire page. It looks a bit like when you use the same piece of paper 5 or 6 times.
  • 46 Answers
You have not stated if it is a laser or inkjet.
On laser machines this can usually be one/both of.
1 Faulty toner / poor quality refill (sometimes happens as toner runs low. (Replace toner)
2 Wear in the drum unit (Replace Drum unit)
Posted on Jul 01, 2009
MFC 240C print quality is excellent but prints crooked on page. Ran alignment multiple times, no help.
When the paper does not feed straight, dirty or sticky rollers can cause it to jamb or crinkle, also failure to remove all traces of paper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these pieces of paper. The rollers may be dirty or sticky and causes the paper to not feed straight.
Try cleaning the rollers with methylated spirits.
Mar 30, 2013 | Brother Multi-Function Center MFC-240C...
Xerox 6180mfp repeating pattern
They are caused by a component in the toner cartridge.
Originally the cleaning roller was a plain roller, but at some time the 'bean counters' decided they could save a tiny bit of money on each cartridge by using a spiral foam roller instead. The foam also seems to be of a different type, and doesn't age well.
There are two solutions.
1. Replace the cartridge that is producing the coloured squiggle/
2, dismantle an OLD cartridge and if it has a plain (non-spiral) foam roller, swap that (along with it's supports - the new type are a different size).
Either of the above will cure the problem, but a new replacement cartridge may also show the problem in time, as it WILL have the spiral cleaning roller.
Nov 15, 2012 | Xerox Phaser 6180N Laser Printer
Printing with double lines and blurry on left side of the page
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 19, 2009 | HP DeskJet 1220c InkJet Printer
Prints streaks of lines with fussy & unclear colur
Yes cleaning the LED heads do make a difference. If they are even the slightest bit dirty your output will be affected. However the quality of the prints on these printers are not very good. I have 3 of them and all of the product subpar quality (right out of the box) especially with lighter solid background colors.
On card stock (especially coated card stock) you'll notice shading on the entire page. Again this happened out of the box on all three of my printers. I researched this and read that it was an effect of the LED technology.
Also if you look closely at your prints you'll notice that there are bars in your print. These bars look like there could be something wrong with the LED matrix...
I just installed a magicolor 7450 II and man what a difference. No shading, perfect picture quality, and larger banner printing (12" x 47") Of course the price tag is a lot more ($3k)
Apr 19, 2009 | OKI C3400n Laser Printer
Paper comes out looking a shade darker, almost dirty.
9 out of 10 times this is caused by dirty contacts. It can also be caused by some electrical charge getting to the paper as it goes through the printer or a faulty (weak) power supply board. Your first check should be to remove all of the consumables and clean all metal contacts with an alcohol wipe or similar. Hope this helps.
Please take a moment to rate this solution, thanks.
Mar 26, 2009 | HP Color LaserJet 2600n Printer
Sooty background won't go away
You most likely need to get a maintenece kit on it what that includes is the fuser. It could be tht the fuser itself is damaged or has burnt toner on it causing it to apear dirty
Feb 12, 2009 | HP LaserJet 2605DTN Color Printer
Printer sends out extra page everytime I print
either your paper size settings need to be adjusted in the software, or your setup has included a seperator page.
Jan 27, 2009 | Office Equipment & Supplies
Text is not readable
It sounds like an alignment issue. If the first line prints correctly, there could be something stuck in the print-head path (like a piece of paper) or the "encoder strip or wheel" could be dirty.
Unfortunately the unit would have to be opened and inspected.
Lift the lid and look under the top cover to the extreme left and right to make sure there is no loose piece of crumpled paper stuck inside.
If this doesn't produce any results, try printing out the alignment page. Press Ink, then test print, then alignment. Print the page. There should be two sets of patterns. Zero represents a perfect pattern. Enter the number beside the pattern that looks closest to zero. You can see a line to each side of each pattern. Always choose the pattern where the line looks like one line, and not like two. If all you can see is patterns with two lines beside them always choose the lines that are closest together. The machine will move your selection to position 5. Print out the test again and select the best pattern again. Keep doing this until the checkerboard effect disappears, and the two lines on each side of pattern 5 have become one line. You may have to do this 10-15 times IF the alignment has gotten really bad.
If this doesn't help, or if it gets worse the unit will have to be opened and the encoder strip and encoder wheel cleaned or replaced.
Jan 14, 2009 | Brother MFC 420CN All-In-One InkJet...
Prints have a dark shade
Test page printed properly. Don't know what to look for in the test page or the applications. the cartridge was changed recently
Feb 24, 2008 | Brother MFC 9700 All-In-One Laser Printer
Printing black shaded on complete page
Problem is usually a dirty charge corona wire. There is a cleaner on the drum unit, slide this across and back 2 or 3 times. If not, then the corona wire itself is missing or broken, change drum.
Feb 19, 2008 | Brother IntelliFax-2820 Laser Fax
141 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
