Question about Garmin nuvi 205W GPS Receiver
I cannot enter an address. Not my home, not "Where to", NONE.
I have great gps signal, battery strength and all. I cant enter any address for the "Where To", or for my own home address. I tried different abbreviations, spellings, different cities, streets, everything. Nothing works. It always says...."No Match Found" I have the Garmin Nuvi 205w. Please help!
  • Garmin Master
  • 2,130 Answers
Please see this link. Your map is turned off.
http://www.sharc.net/discus/messages/6/75.html?1239690151
Please rate my solution if it helped you.
- Jim
Posted on Jul 01, 2009
I have the belkin router in my home and one of my laptops are not picking up the signal for the router
Probably the Router signal strength is low.
You need to open the EWS page ( Router configuration page ) and increase the signal strength to 11 ( it must be Auto or 1,2,3, etc )
EWS Page ( Router page ) can be opened using the Router IP Address which may be 192.168.1.1 or if you know it. Open Internet Explorer and enter the ip address and hit enter ( without www or .com )
Under Wireless configuration or settings you will find the Channel Strength. You need to restart your Laptop to get connected again to the network after saving the settings are you will loose the internet connection.
Regards,
Shawn
Feb 01, 2011 | Acer Computers & Internet
When should I use the car charger
You can charge while driving, but I have been told that every so often you should let the battery run flat. If you dont have to put your home address as your home location, enter an address 2 streets away, it will be close enough for you to know your way home or just enter it as one of your favourites under you first name or something.
If this helps please rate me
Dec 31, 2009 | Tomtom ONE 130 GPS Receiver
How to change home address
using your touch screen, go to tools> my data> set home location> you can use your current position or you can enter it. then it will be save as a home address
Sep 27, 2009 | Garmin nuvi 265 Car GPS Receiver
Can't get a GPS signal for last 24 hrs
I had a similar problem and did solve it with the soft reset (pressing reset button). I have a One XL and there is a small reset button that you push with a paper clip. On the XL 330 you press and hold the on/off button for 15 seconds and the unit should reset.
My symptoms: Would not find a GPS signal. When I looked at the GPS Satellite status (press on the GPS signal strength bars, again on the GPS/battery status) you can see it locking on up to 8 satellites but would still not show a gps signal lock. Normally it only takes 4 satellites to get a gps lock. My other sympton was that when I attached the GPS unit to the computer and operated it with TomTom Home, it worked fine and locked on to the gps signal quickly (even inside my home). But it would never (at least for 30 minute trips) lock on to a gps signal. After doing a reset it began working normally and locked on to a gps signal after finding 4 or more satellite signals.
Aug 06, 2009 | Tomtom XL 330 Car GPS Receiver
We keep loosing contact to the sattelites. Is there a way to reset it, so we get a constant signal?
Mine did the same, and said no gps no fix. I called the factory, now called Northstar, tech said to reset unit, and it worked. Great signal strength. Turn unit on and access menu, access factory settings,hit factory reset. However you will lose all your waypoints.
Jul 04, 2009 | Navman Tracker 5500i GPS Receiver
Entered wrong num. in add. now cant erase it.
select TOOLS then Data then delete home address
Jun 16, 2009 | Garmin nuvi 255W GPS Receiver
Chanage Home address on sony nv-u44 GPS
Go to the "General" settings window.
Scroll down to page 3/6
Tap on "Input Home Address"
Tap on "Enter Address" and enter your new details
Tap on "Save" to save the changes.
Jan 29, 2009 | Sony NV-U44 GPS Receiver
Home update
Is the signal Strength when your outdoor is high??...If not then there can be a problem with your antenea...Thank you..
Please post back for further assistance..
Kind Regards!!...
Jul 31, 2008 | Tomtom One Europe v2 GPS Receiver
Nav-Cam 7000 Question
Sit outside in your car and enter home address using GPS position option
Apr 11, 2008 | Evesham Nav-Cam 7700 GPS Receiver
GARMIN BASICS FOR THE ELECTRONICALLY CHALLENGED
first turn it on and let the unit acquire satellites to find your home state. Then you can set up your address as your "home location". When I first set it up, I was able to pick up the satellites in my bedroom (scary....)...everything worked just fine.
Nov 26, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin nuvi 205W GPS Receiver Logo
306 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
