Question about Dryers
Hello, I have a Kitchenaid Superba mod.
Hello, I have a Kitchenaid Superba mod. #KEYS850LQ1 electric dryer. It will not start, & will occasionally "click'' or ''tick'' like it will before starting the unit. I replaced the door switch for a similar issue about 3 months ago. Difference here is that it has turned on by itself after I left it (while still in the dry cycle and had depressed the start switch). Any ideas?Thanks,Todd
  • tjmuss Jul 01, 2009
    Vic,
    I checked continuity for what I believe your fuse (white 2 prong, looks like a diamond). It's ok, tested door switch,ok..I think the issue may either be the start switch (tested it, infinity to .003, the opposite pole either no change or fluctuating numbers). The timer was what I was begining to suspect. The machine will normally "click" or "hum" once you have set the desired time selection...it does not do that now. I do not know how to test this. I was getting ready to find a start switch
    President:
  • 1,136 Answers
Hi Todd,
First UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Vic
Thanks
Vic
Posted on Jul 01, 2009
How to unlock a kitchenaid superba stove
How-To Unlock A Kitchenaid Superba Oven - YouTube
? 1:24
www.youtube.com/watch?v=yKNGTVCEiuM
Sep 22, 2014 - Uploaded by Public Relations & Promotions
How-To Unlock A Kitchenaid Superba Oven ... Repair - Deadoven after self clean mode, blank display, locked door Kitchen
Sep 09, 2015 | KitchenAid Kitchen Ranges
Kitchenaid superba electric dryer doesn't dry on timed dry
Sounds like a controller problem. May be unable to start a normal dry cycle
Sep 11, 2012 | KitchenAid Dryers
The drum turns and the dyer blows air. It does not light, when I took it apart the ignitor does not come on. We replaced our gas coils about a year ago. what do you think might be causing the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 26, 2011 | KitchenAid KGYS850LT Gas Dryer
I have a kitchen aid dryer SUPERBA electric dryer. It stopped drying. still runs ok but no heat. Checket the Element . looks fine . what could be the reason.?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 05, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Our Kitchenaid dryer won't heat up - it's still under warranty, but we have a 2 month old and need it working asap - it runs and stops fine. For the past few months it has been turning itself on and off...
Hello, Before you proceed you should understand any service you perform on your dryer could potentially void any warranty, It is your discretion. I wouldn't be too concerned about the unit cycling on & off at the end of a cycle, many dryer's have an automatic "wrinkle guard" feature and that is how they function and some cycle on & off for up to an hour after or until the door is opened. I also am not clear if it is gas or electric soooo...if it's electric, disconnect the vent from the dryer and run a "timed" dry cycle not "auto-dry" without a load and see how it perform's. If it performs ok then you have your problem...poor or blocked venting. On the other hand if it is gas, you should not run the unit without it exhausting outside and consiquently you'll have to wait for a authorized pro. The other thing you want to investigate is how well the washer is spinning the clothes, are they fairly well rinsed before entering the dryer ? Just something to consider, obviously soaking wet is not good for drying in the dryer. Let me know if any of this help's and I'll watch for your response. Good luck and thanks for coming to fixya today. Please rate the info provided positively if helpful and reply to me if not helpful. Thanks again, macmarkus :)
Mar 29, 2010 | KitchenAid Dryers
Replacing moisture sensor in Kitchenaid dryer. I have Kitchen Aid electric superba dryer model KEYS850GT0, ~15 years old. Runs great except the moisture sensor came out into the drum. The part appears to...
Go to www.repairclinic.com and enter KEYS850GT0. With luck you will be presented with a list of common replacement parts and may be able to view a generic KitchenAid dryer disassembly video.
Jul 17, 2017 | KitchenAid Dryers
Dryer won't dry clothes
Check your motor and your coils sounds like one of them drawing to many amps.
Here is a site with test procedures.
http://www.acmehowto.com/howto/appliance/dryer/diagedryer.php
Nov 11, 2009 | Dryers
KitchenAid Superba Microwave/Oven, Microway Door message
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Dec 20, 2008 | Ovens
Open Questions:
Dryers Logo
163 people viewed this question
Top Dryers Experts
