Back light for my flat screen monitor
Where can i buy a backlight for my monitor
  • 4 more comments
  • smchilled Jan 08, 2008
    My monitor is dark however when I shine a flashlight on it I can see the desktop. So I guess a light is out on the monitor but I don't know for sure or how to fix it if that is the problem. Thanks for any help, smc
  • Niels Nielsen Mar 24, 2008
    I have a HP Compaq Presario V2000 that is 2+ years old.
    The back light on my monitor is out. I would like to repair it myself. What is the procedure and where do I get parts?
  • p-freeman Jun 18, 2008
    The desktop icons are nearly invisible on the laptop monitor. What is the problem?
  • tman563 Aug 01, 2008
    backlight problem on hp nx9030 real dim
  • lmayer Aug 06, 2008
    the backlite in my HP nx9030 goes off and on - an intermittent problem. Help.
  • Anonymous Dec 02, 2008
    my lcd backlight doesn't come on. where i can find parts for my lcd (hp nx9030)
    Sergeant:
  • 324 Answers
Follow this link for one source.
http://www.lcdparts.net/ccfl.aspx
Ron-
Posted on Nov 09, 2007
My monitor is a dell 2000 flat screen 20.1" turns
This is a backlight problem. The picture is there but there is no light from behind the LCD screen. It could be due to faulty capacitors, which are easy to replace. It could be a faulty Inverter transformer, which is harder to fix but he backlight controller board can usually be replaced at a reasonable price. If you have soldering experience you may be able to replace the faulty capacitors - look for capacitors with bulging tops.
Repalcing the inverter board in a job for someone with electronics experience. You can buy a universal inverter board for about £15 to £20 from e-bay.
20 inch monitors can be bought for about £100 to £150 so you need to decide whether it is economical to repair.
Feb 18, 2011 | Dell UltraSharp 2000FP 20.1" Flat Panel...
It started flickering then went black. When powered off and then back on, it will work for a couple of seconds then go black.
Hi!
I think what your monitor is experiencing right now is because of the backlight inverter in your lcd monitor is about to give up...The backlight inverter is a cold cathode light thats responsible for the image in your screen.. if the lights located on the upper and lower edge of the monitor will be busted then what you will see is black screen.. You will need to replace that in your monitor.
However, without the proper skills to do that and proper tools to open the monitor.. it will be risky for the safety of your monitor..
I suggest that you bring your monitor to a credible technician to replace busted backlight or (burned high voltage ballast transformer - supplying current to backlight)
I hope this help..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Monitor shows picture then goes black, if you hold light to screen you can see picture
Sounds like your backlight has gone faulty, this is a pretty easy repair, however it can be either the inverter, the power supply, or the lamp itself. You really need a service manual, to see how to do it and troubleshoot, exactly locate your fault. Otherwise,all one can do, is swap out, know good for bad, starting with the Power Supply, and working back, as if PSU isn't working 100% nothing else can do.
May 08, 2010 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
No back lighting
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 13, 2009 | Philips 150B5CG (Gray) 15 inch LCD Monitor
It turns off after 10 minutes working
When you say it turns off, is the power light going out too?
If the power light is still lit when the screen blanks, it may be a faulty backlight inverter.
After 10 minutes elapse and the screen goes out, if you power it back on, do you get another 10 min, or does it last a much shorter time period, or not at all?
Your best bet is probably simply to buy a new monitor, and sell yours as "broken" on eBay, I'm sure someone out there capable of fixing it would be willing to pay pennies on the dollar to subsidize your replacement screen.
Jul 03, 2009 | Gateway FPD1965 19" Flat Panel LCD Monitor
My screen is faded kind of like the backlight is out
Yes I can. Sounds like a laptop or flat panel display. Both have a small florescent bulb in them that backlights the screen.
If you can order the bulb the bulb is easy to replace.
Laptop/Monitor: Split the plastic case around the lid/monitor (if there are screws you will need to remove them - check under the rubber pads on the inside of the lid as they often hide screws underneath.)
Run a small knife or flat screw driver around the seam and the two halves will split apart. Once you have done so you can easily access the bulb - replace it - reassembly is reverse of dis assembly.
Feb 06, 2009 | HP 98785A 16" Monitor
Flat screen monitor
Possibly a bad inverter that turns on the fluorescent backlight or a bad bulb.
Jan 17, 2009 | Envision EN-7100e 17" Flat Panel LCD...
Dark screen of Gateway FPD 1520
If you can see the screen display an image upon close scrutiny, it could be that the florescent back light is burned out.
Aug 03, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
No display
With the monitor hooked up and the computer on, you can take a bright flashlight and shine it on the screen and see if it is displaying a picture. If you can see a picture then you can go the route of fixing your back light. I have a spot light that I use and it works really well. If you can't see anything then you are probably SOL and have to replace the monitor.
May 14, 2008 | HP Compaq FP 7317 17" Flat Panel LCD...
Computers & Internet Logo
855 people viewed this question
David Payne
David Payne
