Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Could you tell me what the expected cycle time should be? I have water sitting in bottom for hours.
Roughly 90 minutes on Programme 1
Posted on Jul 06, 2009
I have water in my salt hopper water softner
In most tank style systems that is normal. Since you did not post a make and model number it is hard to tell. The water is called brine and it is very salty. It sits in the bottom till a regeneration cycle and then is pumped into the media beads to clean the minerals off them.
Mar 27, 2017 | Water Dispensing & Filtration
Lifters tap loud in mornings for a couple mins and then good alday
Typical lifter,they are worn,Make sure the oil level is correct. If it is and this noise happens its typical for worn lifter to loose the oil and drain out, After it sits for more than 5 hours the lifter get empty and as you start it up the oil pump/crankshaft builds pressure and fills the lifter right up,this allow the lifter to maintain compression. The valve portion of the engine work 2 to 4 times harder and faster than the bottom portion yes you can still drive it all day,but you can expect this to occur everytime it sit for more than 5 hours.
Apr 24, 2011 | 2002 Pontiac Grand Prix
I have a 97 Dodge Stratus and Drove earlier today No Problem, sitting in driveway for 2 hour no probem the on the 3rd hours I notice a pool of antifreeze under vehicle. Dripping from Passanger Side about a...
check the temp gauge in the car, is it overheating? If it isn't, check the engine where the belts are. If there is coolant coming from there, it is probably the waterpump. If it is further in front of the engine, probably the radiator.
Oct 16, 2010 | 1997 Dodge Stratus
Washing cycle on a 40degree op. takes more than
Don't forget that the reason you bought a front loading washer is for the efficiency of the washing. In other words, front loaders use less water and get clothes cleaner without all the harsh beating that the older agitator units do.
If you're using any of the pre-programmed wash cycles, you might want to tgry another cycle to see how it does for getting your clothes clean with a shorter cycle.
If you check your owners manual, it should provide the cycle times for the various wash and water temp settings. The colder the water you use, the longer the wash cycle typically is, since it takes more agitation and time to get clothes clean, especially with front loading machines. Hope this helps.
Jul 28, 2009 | Whirlpool WFW9200S Front Load Washer
Bosch dishwasher shu3032uc-14 doesn't clean very well tried different things but no help sometimes i can catch top spinner not working all the holes are clean where is the water level supposed to be and...
Pour a gallon of white vinegar in bottom run halfway thru wash cycle turn off let unit sit overnight to properly soak-then run a couple of times to rinse out vinegar(vinegar dissolves calcium which causes unit to not function properly) also check unit inlet for contaminates and clean as neccesary install inline filter if not one there..(the hot water tank will tell if you have a calcium problem(hard water problem)shut off unit undo relief valve on tank hook up hose to bottom then drain check for white chunks),calcium wreaks havoc on all household appliances and shortens there lifespan!!! :)
Jul 05, 2009 | Dishwashers
Water from the cycle remains in the bottom of the washer.
Sure we can help, what are we sitting here for. And don't forget, ITS FREEE. (The weight of the washer is not the water, but concrete blocks to counter balance your clothes; so the machine does not fly off when it spins.) The draining involves several factors, giving you the most common. If you surf this site you'll find your solution. Solution is for another machine, but could be helpful for you: The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in. Plz rate if helped.......
Apr 02, 2009 | Washing Machines
Long cycles on my whirlpool duet washer
it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water is collects in drum after a few hours after cycle is complete
no your inlet water valve is defective, youll need to repalce it, part number 8181694. in the mean time just turn off water in beween usages.
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Water in bottom of dishwasher
You could have a defective fill valve that is not shutting off properly. Look for a fill inlet opening somewhere on the inside casing of the wash tub. Usually it is on the left hand side of the machine looking in. While the dishwasher is sitting idle, watch the fill valve opening to see if water is leaking in. It could be a minor as just a drip. However, over a period of several hours you could end up with a wash tub full of water. Over a weekend with no one home, it could overflow onto the floor. The valve usually cannot be repaired and would require replacing. Good luck.
Jun 12, 2007 | Bosch 24 in. SGS43C12 Classixx...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
172 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
