Question about Northstar Electric Wet Steam & Hot Water Pressure Washer 1700 PSI
Pressure will not build up in North Star electric wet steam 120V.
When the switch is turned on to start the compressor motor and build pressure, the motor starts but no pressure builds. After ~5 seconds the motor stops and the switch must be turned off and then switched back on, but the same thing happens over and over. I have played with the adjustable pressure regulator valve to the extremes of plus and minus and in the middle, but no luck. The time for compression to start has increased over time until now it won't pressurize at all. The oil level indicator window in the compressor oil sump shows there is plenty of oil. I have had this machine since 2001 and have used it occaisionally during that time.
  • 34 Answers
CHECK THE INTAKE FILTER-MAY NEED A NEW ONE.
Posted on Jul 01, 2009
Coleman POWERMATE Lo502710. Compressor runs and builds up pressure and then keeps on running even when 100 PSI. It will not shut off. I do not hear a leak when I pull the electric plug to make it stop...
There is a problem with your pressure switch. You should have a little black box with a red lever to turn your air compressor on and off. This housing contains your pressure switch, the pressure switch sends an electrical signal to the switch to make your air compressor run. When enough pressure builds up the pressure switch activates, and breaks the signal until the pressure drops below a certain point. I will do some more research on your compressor and find out which pressure switch you need to order. i need you to find any numbers on the compressor you can, serial number, model, stock number, anything you can to help me find the part number.
Thank you for patience,
Calvin Smith
Nov 19, 2011 | Coleman Powermate 27 Gallon Air Compressor
Comperrsor pumps uoto preassure, but when the preasure drops it tries to start . The motor come on but will not turn compressor until preasure drops to about 20 lb. Then it will start and build up to...
Run the compressor until there is about 75 psi in the tank and turn it off at the pressure switch. Remove the black bleeder line from the pressure switch:
1. If absolutely no air comes out of the line you may have a bad start capacitor on the motor. Have it tested at an electrical or refrigeration shop or just replace it to see if it takes care of your problem.
2. If you get a short blast (five or so seconds) of air then nothing your pressure switch isn't letting the head pressure bleed off after the motor shuts off. This pressure has to be relieved or the motor has to fight the tank pressure when it tries to restart. Reconnect the bleed off line and turn the motor back on. If it starts normally, replace the pressure switch. If it struggles or won't start it is more indicative of a bad start capacitor.
3. If you get constant air flow from the bleed line the problem is with your tank check valve. This causes the same problem as above. Replace the check valve.
May 04, 2011 | Ingersoll Rand 30 Gallon Garage Mate...
Compressor runs to 175psi but trips pressure relief when pressure drops tries to restart motor but motor wont turn blows breaker. changed whole pressure switch have same problem.
The problem is lilkely the check valve between the compressor and the tank -- it is alowing pressure to build from tank to compressor preventing the compressor from turning over. Clean, maybe replace, check valve...
Charlie
Jan 09, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
I have a 3 phase electrical motor for my air compressor, How would i connect this from the air compressor pressure switch and towards the electrical source 120V? (for low volt)
If the electrical 120 volt source is single phase, the only way to run this motor is with a single phase to three phase converter. Best to sell the three phase motor and obtain a similar horsepower 120 volt single-phase capacitor-start motor (1750 RPM) for the compressor. You would also require a 3-phase pressure switch for use with the 3-phase motor. Hope this helps!
Nov 05, 2010 | Garden
Will only build pressure to 100psi of rated 140psi
Chances are that the pressure switch, were you turn the compressor on and off, is bad. When they go out, they no longer build pressure to the regulated level you are looking for. If you haven't already, try turning up the regulator, if no more than 100psi build's, then it's a sure thing, bad pressure switch.
Oct 11, 2010 | Makita MAC5200 Electric Powered Air...
Electric compressor will not start up im getting power thru the switch but comp.doesnt attempt to start.
your pressure switch is defective that controls the cycling of the motor,its fed air pressure off the tank line and opens and closes contacts to start and stop the motor to build air pressure when needed
Jul 17, 2010 | Campbell Hausfeld 26 - Gallon Air...
My compressor suddenly quit cycling what went wrong?
hi there!
there are several factor on cycling failure, most common on it is the pressure switch device,checking on this,plug out or switch off main circuit breaker for compressor, disconnect pressure switch if this is a single phase connection,there are two supply wire coming in and two wire coming out on pressure switch.direct connection of compressor motor on power supply to test if it is cycling manually,after direct connection of motor compressor to power supply w/out pressure switch,switch on for 5 to 10 minutes o build a low [pressure then swict off again,then switch on again even there is a low pressure observe if there is cycling motor running if this done replace pressure switch.if still have same problem motor tripping another case not to cycle bring this to electric motor service center.have a nice day dont forget to fix my rate.
May 07, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
EC-12 runs but only builds to 35 psi and continues to run
It looks like there might be a knob which sets the max air pressure coming from the compressor. If there is one, this may have been turned down.
There are usually 3 pressure settings on an electric compressor. Compressor max, pressure switch cut on, and pressure switch cut off.
Apr 29, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Northstar Electric Wet Steam & Hot Water Pressure Washer 1700 PSI Logo
360 people viewed this question
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
