It only came with the power cord and nothing else what else would it need and would that be the solution instead of replacing the bulb on it?
    President:
  • 1,383 Answers
Change power code if power is not on.
Aslo check bulb is properly working.
Reset all settings to factory defautls in settings .menu.
Reattch all connectin to it.
Posted on Jul 01, 2009
  • kishor
    kishor Jul 01, 2009
    Itonly need power code and dispaly vga cable to give input.
Has the fuse blown on my machine? It doesn't turn on anymore. I changed the bulb and accidentally put in a 25W instead of a max 15W and it turned on for a few mins until i started sewing and it cut.
Hello Jess
Your manual is listed below, but I don't see a fuse or a reset button at a quick glance.
However, open up the area where the bulb is and look for a reset button. Also look on the foot pedal. Plug something else into the wall outlet to verify that a breaker hasn't tripped.
Did the machine work with no bulb alight? Wondering if the bulb must be working and present for the machine to function for safety reasons?
You know there is an On/Off switch above the power cord on the back of the machine, PAGE 6, Figure 1 in the manual?
http://www.singerco.com/uploads/download/38b237687d4dcaa62be10a78bb352508437b5509.pdf
Jul 02, 2016 | Singer 2250 Tradition
Why when I was sewing one minute and the next it stopped completly and my light went out. Put in new bulb nothing still works?
You machine has an electrical disconnection somewhere. Most likely it is in the power cord, but could also be inside the machine itself.
Best to take it for repair unless you can test with a different power cord.
Jan 11, 2016 | Sewing Machines
Can't get anything on screen. How do I know if bulb needs replacement?
Before you go any further it might be a good idea to check for high voltage on crt surface. Take a small piece of toilet paper and see if it sticks to screen when you turn it on. If it does not then lack of HV is your issue and not your crts.
Oct 10, 2015 | Televison & Video
I have a Mitsubishi 60 inch TV new bulb replaced it won't light up what else could be wrong with it thank you
Look in the circuit board area where the power cord mates with it for capacitors that have bulging tops (instead of the flat tops that are normal). If you see even one, you need to replace all the large capacitors othe power supply section (normally around 5 or 6).
Dec 08, 2014 | Televison & Video
Power cord pluged in, turn on computer entered password, screen went black, power on button blinks green instead of steady on, wont do nothing else, what happened, what do i do now?
Unplug the power cord. Remove the battery. Press and hold the power button for 60 seconds then release. Plug the power cord back in but leave the battery out and try to turn it on now. If it comes on you can put your battery back in. If it still does not come on you may need a new power supply/ adapter.
Apr 06, 2011 | Acer Computers & Internet
Kirby G6 - won't power on
Check the cords two wires with an OHM meter for continuity replace if you get a reading showing OL The ground wire you can forget about this test
If any sort of numbers appear in the meters display the cord is good
Replace the switch instead
Jul 10, 2010 | Kirby G6 Bagged Upright Vacuum
Has power to unit but nothing works, ie. oven, clock, timers, etc
If you don't see any light in the display or from the light bulb inside it you probably need to replace the fuse inside the microwave, it should be by the place where the cord goes in the microwave.
Apr 08, 2009 | General Electric Microwave Oven
No Power
me too anyone find a fix?
Dec 09, 2007 | Optoma EzPro 739 Multimedia Projector
Dryer not working
Assuming the problem is associated with you changing the cord, it sounds like you have a wire crossed on the power cord. Double check how you have the cord installed first. If that is correct check your power to the dryer. Since you changed the type of cord, I assume you have had outlet replaced or have just moved to new house. If you have a fuse box instead of a breaker box, check your fuses. It takes two fuses for the dryer. If one of them blows, the motor will run but you wont get heat. The motor runs on 120 but it needs 240 for the element. I can't count how many people have bought a new dryer just to find out they only had a house fuse blown and nothing was wrong with their old dryer. If you have had wall outlet changed there could be a wire crossed in it.
Oct 05, 2007 | Roper REX3614KW Electric Dryer
PROVIEW PL-456S LCD MONITOR TURNING PINK ON ONE SIDE
Chances are that you are not hurting anything with the lower power supply. What is probably happening is most likely two fold. 1. The light bulbs in the backlight circuit may just be wearing out and need replacement, and 2. the lower current power supply may not be capable of producing al the current that the monitor needs at certain times during operation. I would suggest getting hold of the correct power supply module and see where that gets you. If you still have the red outs,replace the light bulbs in the monitor. The only other fault than that would have to be in the video controller. Hope this helps.
Oct 03, 2007 | Proview PL 566s 15" Flat Panel LCD Monitor
Televison & Video Logo
Top Televison & Video Experts
