Question about Whirlpool ARC4030 Stainless Steel Top Freezer Refrigerator
Whirlpool freezer for ikea has a red light on and alarm
My whirlpool freezer for ikea has a red light on and the alarm is sounding how do I reset it or turn off
3 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: Alarm is constantly bleeping on
may need the model number but try pushing the light button 5 time in 15 sec,, if it will not work send the model number
Posted on Sep 07, 2008
sodeep
  • 3267 Answers
SOURCE: Red alarm light is on on Westinghouse upright freezer
Most probably during transportation either the coolant(previously freon gas) may have leaked out so the pressure on the cooling pipeline causing the red alarm because the compressor will overheat if the fridge is kept running at very cold thermostat readings and no effect of cooling the fridge will ultimately result in the compressor getting burnt. However fist have look at thermostat setting knob which could have loosened during transportation and just pushed into the spindle without knowing the correct angle, thus even though it looks as if on high cool but could also be the lowest setting..........sodeep
Posted on May 19, 2009
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Red alarm light flashing
Good Morning Friend, thank you for allowing me to assist you!
Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your freezer by unplugging it or flipping the household circuit breaker. It is good to wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause. - Z
Jul 18, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
How to reset the alarm on freezer
Hello Friend, this is Z. Thank you for allowing me to assist you!
Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your freezer by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Best regards!
Jul 14, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Why is the red light flashing on my zft810fw freezer when it is freezing ok inside
Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
Jul 08, 2014 | Zanussi Freezers
Why is the temperature alarm light on, on my freezer Model# FFU21M8CW?
Good Afternoon Friend,
I understand that the temperature alarm light is on for your Frigidaire freezer, model# FFU21M8CW. This feature is designed to provide a warning of a possible malfunction. If the temperature of the food rises to a level unsafe for long-term storage, the buzzer will sound. The red light, if equipped, will also glow. The Temp Alarm feature operates on household electricity. If power fails, the alarm will not function. An ON/OFF switch allows you to deactivate the Temp Alarm when not wanted. Your freezer is shipped with the Temp Alarm in the OFF position. After your freezer has run approximately 4 hours, the red light, if equipped, will go off. Then you may activate the Temp Alarm without the alarm sounding. Press the ON switch to activate the Temp Alarm. To deactivate, press the OFF switch. If the alarm sounds, be sure freezer is properly leveled, and the door closes freely, and seals properly. If you suspect a technical malfunction, call an authorized servicer immediately. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
What does the red warning light by the triangle mean on a blomberg
food.
Dado
May 28, 2014 | Zanussi 10.31 cu. ft. / 292 liter Chest...
Whirlpool freezer AFG 8060 indicates red light and sounds alarm. Temp always held at -16 to -20, though now indicates only -1.
Please check : - Your door for small leak ( gasket / seals) - Temperature sensor for malfunction. A failed sensor will show wrong data.
Regards,
Dec 04, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
Philips whirlpool AFG 027 freezer
The orange button is the "turbo boost" - for reduzing the temperature the fast way. Mostly used when first time use or you put in a lot of unfrozen things at once. When reaching optimal temperture it goes off automatically. The red one is the alert button. Not sure about the green one. Under normal conditions none of the lights is on.
Apr 02, 2008 | Freezers
Temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Whirlpool ARC4030 Stainless Steel Top Freezer Refrigerator Logo
303 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
