Question about Sony Cyber-shot DSC-W50 Digital Camera
Hey, is not working
I wonder what happened with my camera...when I put it on, the lens will go back and forth and then the screen is not working, it's not working at all because of this on and off thing. What could be the possible reason?
  • cilmt Nov 19, 2007
    i'm having same troubles. access appears on the screen and the lens keeps popping back and forth
Try hitting the camera against your hand a couple times. sounds crazy but it actually works.
Posted on May 30, 2008
Does not autofocus
Assuming you've made sure the auto-focus is turned on on both the lens and the camera, remove the lens, turn off the camera. Remove the battery. Wait about a minute. Put the lens back on, turn the camera back on . It's a computer basically. Sometimes it crashes. I've had this happen to me a few times.
Mar 13, 2012 | Nikon D90 Digital Camera with 18-105mm...
I was taking pictures, but paused for a moment to find a better angle. I guess I got distracted for a few minutes. I went back to the camera to see that the screen was black. I thought it had turned itself...
Hi. Yes, that happened to me once. Battery went dead and doesn't have enough power left to retract the lens. Camera worked fine after I put in charged battery. I hope this is your case too.
Aug 25, 2010 | Cameras
Having Trouble with my Olympus FE-3010
My Olympus FE-3010 camera has just done exactly the same thing and it's also 4 months old. I don't know what to do either.
Sep 18, 2009 | Cameras
Olympus 3010 Card Access Lamp is ORANGE and lens extended
Mine has same problem -- Dont buy a new battery , I tried that but it still does the same thing--- Sorry I know how you feel -- very frustrated I think!
Aug 02, 2009 | Cameras
Lens error,restart camera
My Camera: Canon PowerShot SD770 IS Digital Camera
Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down)
2. Gently tap the sides of the camera (to loosen particles in lens)
3. Turn camera on
4. The lens will eventually come out
5. Gently tap the sides of the lens
6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Now the camera works...thank god.
Aug 31, 2008 | Canon PowerShot SD600 Digital Camera
Lens error
ok,i had this problem & couldnt find solution anywhere,so i took the back off the camera to reveal the lense unit.Now there is 2 screws in the middle of the back of the lense you need to remove together with ribbon cable.Underneath this is a small square rubber seal which was not seated properly.All i done was to seat it back in the right place,put all back together & hey presto,turned camera on & all was good.
This might not be the same problem you all have but it worked for me.
Good luck !!!
Jun 08, 2008 | Nikon COOLPIX S200 Digital Camera
Digital Camera Fault
ACCESS error could happen when lens gets stuck but if it happens when lens moves back and forth without problem it usually means that where the lens assembly plugs into main system board connection is loose. These connections are held in place by a very small thin fragile plastic clip and a few drops could be enough to snap it but not do any other noticeable damage to camera. Camera would need to be opened to see if clip is broken or maybe cable just needs to me reinserted. Either way only open camera if no longer under warranty and you are somewhat handy
Mar 20, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Won't autofocus
First try another lens on the body and see if the problem is the lens or the body,if its the body the autofocus mirror could be out of adjustment, if its the lens, it sounds like the lens took an impact and needs a pro repair. you should be able to set body to manual focus and focus lens to infinty.
Jun 11, 2007 | Nikon D50 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
23 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
