Fills but will not agitate or drain - Washing Machines
    President:
  • 1,136 Answers
Hi, Sounds like it could be the lid switch. Open the lid and see if the lit switch actuator is boken or hanging down. Get me a model # and I can assist you further.
Vic
Posted on Jul 01, 2009
  • 1214 Answers
SOURCE: its fills with water but then sits & hums - dont agitate,drain
It sounds like the controller/timer is bad. If this is an old dial timer type control, can you turn the control and cause the washer to drain? If so, replace the timer control.
If it's an electronic control, then look for a failed sensor as it's very unlikely to be the control.
Posted on Jan 15, 2009
huuum
  • 750 Answers
SOURCE: whirlpool washer fills, begins to agitate, then drains
Water siphoning out the drain line
If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
moz-screenshot.jpgThe washer fills and drains at the same time only on the rinse cycle.
Shut the machine off with timer during this period and raise the drain hose. If the water continues to drain, you will need to install an anti-siphon kit.
Please leave a solved rating before you sign out
Posted on Jan 31, 2009
Greg20
  • 149 Answers
SOURCE: Fills, does not agitate, drains, spins, fills,
grab the agitator at the base and give it a quick push upward..remove and see if the white dome with bolt holding it down is stripped on the inside where it splines onto the transmission shaft. :)
Posted on Jun 13, 2009
Vanguardian
  • 106 Answers
SOURCE: washer fills,agitates butstops instead of going into the drain an
Most likely it's the door switch that tells the washing machine that the door is open or closed.
It's usually on a lever of some sort as to not get the actual switch wet that contacts the door itself.
With the older machines in particular, they didn't find filling or agitating as dangerous. Only spinning was considered that way, so it could fill and agitate with the door open and spin only when it was closed. When it spins, it also turns the impeller (pump) in the direction to pump the water out.
The other possibility is that the transmission or motor has gone bad. The motor and transmission turn in one direction for agitation and in the opposite direction for spin. If the gears have stripped in the transmission or one of the primary windings has gone on the motor, it simply won't turn in that direction.
Posted on Sep 23, 2009
  • 73 Answers
SOURCE: Washer fills but does not agitate, drains fills
there is a coupling between the motor and the agitator coming out of the gear box if you can hear the motor running when the agitator should be moving then that will be your best bet however if the motor is not running during what should be the agitation cycle then you are probably looking at the sequencer control Good Luck
Posted on Oct 23, 2009
My fisher and faykel washer model wa37t26gw2 does not fill, and will not drain. diagnostic says plugged drain hose, but it is clear from pump to diverter
Your question does not make sense. You say it does not fill but then you say it will agitate. How can it agitate if no water has filled? Does it beep and give an error code/ If so what is the error?
Jul 23, 2016 | Fisher and Paykel Washing Machines
Washer will not Agitate?
Had to send mine to repair for the same issue. They claimed a computer was malfunctioning. There was also an interlock that kept the agitator from engaging. Cost was nil for me because it was under warranty.
Jul 31, 2014 | Whirlpool Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Replaced the belt and still not agitating, switch seems good
If the machine fills, won't agitate, wont drain or spin, then you need to replace the lid switch.
if machines fills, wont agitate, will drain but not spin, then you need to replace the motor coupling
Feb 08, 2011 | Frigidaire FWS1339A Top Load Washer
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Agitator doesn't agitate. Fills, spins and drains
Unfortunately, that sounds like a transmission issue. Power is getting to the trans, or it wouldn't spin, but the other part of the trans that causes agitation is broken.
Nov 15, 2009 | Washing Machines
Washer fills but does not agitate, drains fills again but still no agitation. Drains again and spins. Any suggestions? Model vbxr1060v1ww
Oct 23, 2009 | Washing Machines
Fills, does not agitate, drains, spins, fills, does not agitate, drains, spins
Jun 13, 2009 | Hotpoint VBXR1090D Top Load Washer
Whirlpool washer fills, begins to agitate, then drains
Jan 31, 2009 | Whirlpool LBR4121JQ Top Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
