Question about Kenmore 22642 Top Load Washer
Rinse problem My washer goes through the cylce - But when it gets to the spin cycle, it just sits there - I can hear the water draining right before the spin cycle. I have the lid open - the lid switch works - I can open the lid hold down the lid switch and the washer operates like it suppose to. But when it on the spin cycle - zero happens..... Please advise. Thank you.
  • 672 Answers
Sounds like a timer issue. Try this, Yes it sometimes works. Spin the timer knob vigorously six to ten complete turns. It may be that the contacts are stuck together and this frequently frees them. Timers are expensive, so this is worth a try. Good luck.
Posted on Jul 01, 2009
My Kenmore compact washer with dryer on top, will not go from the first wash-rinse-drain-spin cycle to the second rinse-drain-spin-off cycle.
Check and make sure the door is pushed all the way down until you hear a click. If it starts with the next cycle, then your door switch may be bad. It's a pretty easy fix, but I would watch a video at least before doing it yourself.
Oct 09, 2016 | Kenmore Washing Machines
Washer WPSR3100WOWW Will wash but not drain and spin... Stops at the rinse Cycle
Christina,
Does it leave water inside the tub? There are a couple of possibilitys. One could be the drain pump. If this fails the wash/rinse cycle will stop as it can sense the water not being pumped out. Can you hear the light sound of a small motot running when it goes into rinse cycle? Listen down at the very bottom far right side or far left side. If you hear the drain pump motor running is there any water discharging out the drain tube going into the wall? You should easily hear the flowing water. If not you have a few possible problems: Drain pump has an obstruction in or around it or, drain pump is actually bad.
Oct 12, 2013 | GE WSXH208A Front Load Washer
The washer only goes thru the wash cylce. It will not rinse or drain the water
It sounds like you probably have a defective lid switch. Try pushing it down with a pen or something if you can see it, if the unit will spin. It will not go into a drain cycle if the lid switch is defective. Hope this helps MJ
Jun 09, 2010 | Whirlpool LSR5132PQ Top Load Washer
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Wash will not drain
Hi, When the cycle goes into drain, do you hear the motor humming at all? If the motor does not hum, check the lid switch.
If the washer agitates, there must be a problem with lid switch ot timer. The lid switch is most common.
Please let me know if this helps or if I can assist you further.
Vic
Jun 20, 2009 | Kenmore 22422 Top Load Washer
Water not draining during rinse cycle
check the drive belt for the pump under the machine
May 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Goes through all cycles by will not drain or spin.
If the timer hangs at points in the wash cycle, and you can manually advance, then the timer continues to run or runs shortly before hanging again, then the timer is bad and needs to be replaced.
Jan 24, 2009 | Kenmore 24032\24036 Top Load Washer
Machine will not agitate for wash or rinse cylces
that could be your problem or your drain pump maybe full... try spin and drain see if it will drain
Sep 08, 2008 | GE Energy Star WCVH6260F Front Load Washer
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 22642 Top Load Washer Logo
108 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
