Question about Alpine Type-R SWR-1042D Car Subwoofer
System Cuts Off
Do u have any suggestion as to wat kind of amp or wat kind of power i sould be looking for?... There are so many kinds out there i would not have any idea where to start looking... oh n im not trying to spend a fortune in it!...
  • 790 Answers
Hi
Please tell me the specs of your sub woofer,. and we can match this issue.
Thanks!
Posted on Jul 01, 2009
What kind of fuse for 50pfp5332d?
look on the fuse for amps and volatge it sould tell you may be a peco fuse i dont know of a fixed fuse
Jun 03, 2012 | Philips 50PFP5332D 50 in. Plasma...
Ok so when i turn my bass up my kicker cut out from the power. now im pretty sure its because my remote wire-piece is loose someone please help me resolve this problem. i love this amp it goes perfect wit...
when u say the power cuts out.Do U mean the DC + power. Powers down on the amp. or does the amps protection kick on. and if it does. Is thier a flashing maybe orange/yelloowish light. If this is so. You might want to over look your connecting of your speakers. to see how it is wired.It might be crossed. -or-Is your amp mounted on something other than your vehicle. If it is U might want to remove it,and put it on another type of item that is not some kind of metal. I always use wood. Then i mount wood to A vehicle after the amp. U see A amp is not to be mounted directly to A vehicle. It grounds it out. when go to turn up your system it will cut off or sound like a pulse up and down kind of sound
Sep 09, 2011 | Rockford Fosgate 100a2 Car Audio Amplifier
Getting message - "can't read" & "no disk"
sounds like the laser is out of synk with the encoders inside the player, to fis this you will need to disconnect everything from it, unscrew it and carefully move the lase all the way to the outside of its track, BE CAREFUL NOT TO TOUCH THE LENSE WITH YOUR FINGER, you may also wish to clean the lense while you are in there anyway. To do this dip a cotton swab in Isopropyl alcohol (the kind you use for cuts and scrapes), and roll the tip accross the lense of the laser, just let it air dry. Reassemble the player and it sould be good to go.
Jun 30, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I hv windows7 ultimate in my computer bt its activation has expired. On desktop its written dat this copy of window is nt genuine. So wat to do further to get my system error free. Kindly suggest any...
i hv windows7 ultimate in my computer bt its activation has expired. On desktop its written dat this copy of window is nt genuine. So wat to do further to get my system error free. Kindly suggest any solution so dat i may nt loss my data and free. inf me on y email shin_dragon_pke@yahoo.com help is need ASAP
Jul 02, 2010 | Computers & Internet
My sc-ch900 cuts out after a minutes playing. Is
did u play it real loud? if not, probably not. in most over load problems the system shuts down pretty fast. it will not take minutes if it has an over load protection. it is pretty hard to tell exactly what is wrong with that kind of sophisticated systems unless we take a look inside. it is probably bad power supply within the system. like i always suggest, if warranty covers-replace it. otherwise u have to get it fixed.
Mar 12, 2010 | Technics Audio Players & Recorders
Wat kind of wire should i use power acoustic 3000 class d mono block
What does the fuse on the back say? AWG 4 has around a 60 amp capacity, AWG 2 is about 95 amps. I wouldn't suspect you would need larger than 2. Remember the higher the Gauge the more Resistance per foot you have which means more of a voltage drop at higher current.
Dec 16, 2009 | Power Acoustik A3000DB Car Audio Amplifier
Jonny Rafael Every time i turn on my amp it stops and says Amp Err and shuts down and wont let me turn on like in about 20 min.I dont know wats wrong but i need help please.
Says amp error on the amp? what kind of amp? Have you checked the fuses and are you properly installed ie. remote wire to a remote power source. Properly grounded? Power wire to a constant power source? Please be more specific?
Aug 31, 2008 | Pioneer Audio Players & Recorders
Sub+amp configuration
With a single 4-ohm subwoofer, usually the best choice is a 2-channel amp that can be bridged to a single channel. In your case, the sub is rated for 1000 watts. Not many amps are rated for that kind of continuous power into a 4-ohm load. Kicker doesn't list a minimum power rating, which isn't unusual in subwoofer specs. Depending on your budget, I'd look for an amp rated for 300-500 watts minimum; the higher, the better, up to 1000 watts. Most amps will have several power ratings, based on the load impedance and number of channels driven. A typical 2-channel amp might be rated like this: 150 watts x 2 channels at 4 ohms 300 watts x 2 channels at 2 ohms 500 watts x 1 channel at 4 ohms. The power rating you'll want to look at will be the 1-channel, 4-ohm rating. You can look at mono amps, too, but in the power ranges you're looking for, a 2-channel amp will probably give you the best value. However, if you can find a mono amp with a high enough 4-ohm power rating, it would run cooler and might last longer than a 2-channel amp with comparable power. When looking at mono amps, you'll find their highest power output will be at 2 ohms or 1 ohm; make sure you're checking the 4-ohm rating when making comparisons. Some amplifiers that might work well for you: Kicker SX900.2 Kicker ZX850.2 Alpine PDX-1.1000 Rockford T600-2 Hifonics ZXi 1006 Premier PRS-D2100T Power Acoustik OV2-2200
Jul 05, 2007 | Kicker C12-4 Car Subwoofer
Power & protect
my amp says Lo on the digital circle on top of the amp i have a mtx 9500 bridged to the amp and it cuts out at high volumes and suddenly please help
Dec 21, 2006 | AudioBahn A8000V 400W x 1 Car Amplifier...
Alpine Type-R SWR-1042D Car Subwoofer Logo
70 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
