Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Low pressure reads High. High Pressure reads low???
  • nefmart Jul 01, 2009
    Clarification....This (photo) is not the model. It is a central air heat pump.
    Guru:
  • 588 Answers
Your gages are hooked up backwards, try switching them
Posted on Jul 28, 2009
Has 358000 miles, just had leaks repaired. Twice since my oil pressure gauge reads no pressure but not all the time? Why
1. Oil Pressure Gauge Not Working You will notice this happens when your oil pressure gauge is not reading, whether the engine is turned off, idle or running. Try to step on the gas to rev up the engine. If the oil pressure gauge still doesn't change its reading, your gauge is busted. It's best to replace it as soon as possible because you won't have any idea if your car is already overheating or not.
2. Oil Pressure Gauge Reading Too Low When your engine is idle, the oil pressure gauge will have a low reading. When the engine starts running or when you're already cruising or on the freeway, your gauge's reading should have increased. If it stays on a low reading, then you now your oil pressure gauge is broken.
3. Oil Pressure Gauge Reading Too High Another common oil pressure gauge problem is when your oil pressure gauge is reading too high when your engine is idle or when it's turned off. Rep
Oct 24, 2015 | 2001 GMC Yukon XL
Car a/c not working
Hard to say with just low pressure readings. But either the high pressure switch is bad or you are low on freon. If you want to know what is wrong I need the temperature of outside air, the low pressure reading and the high pressure reading as the compressor is running. But this only tells you ta particular problem. It won't tell you if you have a leak. This you have to find out on your own.
Jun 09, 2015 | 2001 Ford Escape
My low pressure fuel pump on my e270cdi cut out under high load conditions.no pressure from the rear.all fault codes tell me the rail pressure is to low
Fuel pump relay is in cavity A in the rear SAM ( Signal Acquisition Module.) on the left hand side of the trunk behind a door.
When did you check the voltage..... you must read it while cranking or you will get a zero voltage reading.. The low pressure tank pump builds pressure to the high pressure pump and then shuts down until a pressure drop is sensed in the low pressure line and it then starts up again.
If rail pressure is too low, it often is the high pressure pump in the engine or the relief valve in the fuel rail. The tank pump is low pressure just to stop the tandem pump from cavitating by sucking too hard.
Mercedes can check the rail pressure and do an injector pressure drop to rule out a leaking injector.
If the tank pump is bad it will require replacement.
Oct 20, 2013 | Mercedes-Benz Cars & Trucks
I have a 2002 Trail Blazer it not cooling The compressor kick in and out and low side reading 150? What do I need to check?
It's impossible for the low side to read 150 PSI, typical pressure is 35 - 45 PSI. Are you sure you are on the low side and not on the high side? If your compressor is going on and off, maybe your pressure switch is bad or the low side pressure is too low.
Aug 15, 2011 | Chevrolet TrailBlazer Cars & Trucks
How do I check and possibly replace the engine oil pressure sensor in a 2006 GMC Envoy Denali?
Oil Pressure Test Check for proper oil pressure at the sending unit passage with an externally mounted mechanical oil pressure gauge. A tachometer may also be needed, as some specifications may require running the engine at a specific RPM.
  1. While the engine is cold, locate and remove the oil pressure sending unit.
  2. Following the manufacturer's instructions, connect a mechanical oil pressure gauge and, if necessary, a tachometer to the engine.
  3. Start the engine and allow it to idle.
  4. Note and record the oil pressure reading when the engine is cold. The engine may need to run at a specified RPM, if so check the vehicle's specification.
  5. Run the engine until normal operating temperature is reached.
  6. Check the oil pressure reading again with the engine hot and record the value. Turn off the engine.
Compare the hot oil pressure reading to the specification. If the reading is low, check the cold pressure reading against the specification. If the cold pressure is well above the specification, and the hot reading was lower than the specification, the engine may have the wrong viscosity oil. Change the oil, making sure to use the proper grade and quantity, and then repeat the test.
Low oil pressure readings could be attributed to internal component wear, pump related problems, a low oil level, or oil viscosity that is too low. High oil pressure readings could be caused by an overfilled crankcase, too high of an oil viscosity or a faulty pressure relief valve.
Oct 09, 2010 | 2006 GMC Envoy Denali
Need to fill air where is low pressure intake
The a/c has a low pressure port on the low pressure side of the a/c piping system.
One can identify the low side by looking at the 'thicker' pipes vs. the 'thinner' pipes on the high pressure side.
There may be a canister that has a low pressure port on it on the passenger side. Or else, it's on the thicker piping itself.
There may be a blue or black cap on the port.
The pressure should read 35psi to 45 psi on the low side when the a/c clutch is spinning or engaged.
When the a/c clutch is not spinning or engaged then the pressure should read 75 psi to 100 psi on a hot day.
Aug 06, 2010 | 1997 Pontiac Grand Am
AC not cooling for 97 Passat TDI
A/c should be charged on the low side while engine is running. Make sure high side valve is turned off. Low side reading should be around 32-35 psi at idle high side should not go above 250. I hope this helps,good luck
Aug 01, 2009 | 1999 Volkswagen Passat
96 Tahoe no Cold Air
YOU NEED 28 PSI ON LOW SIDE AND ABOUT 190 ON HIGH SIDE.YOUR REFRIGERANT IS LOW THAT WHY COMPRESSOR CYCLING ON AND OFF.
Jul 22, 2009 | 1996 Chevrolet Tahoe
95 Deville - Low Refridgerant/AC Comp. off
To diagnose problems, an A/C manifold gauge set is needed to read high and low side pressure readings. Avoid adding refrigerant with a simple charging kit like the ones sold at parts stores. Don’t add any stop leak, this can cause problems in the compressor, expansion valve or condenser.
Keep in mind that using an A/C gauge set and seeing BOTH high and low side readings can help in diagnosing the problem when you know what to look for. First, on a 134A system the high and low side service ports are different sizes. AC gauge sets have color coded hoses, the blue color coded hose has a connection that fits on the low side service port and the red hose has a connection that will only fit onto the high side. The yellow hose won’t hook up to anything if just checking the readings; it can be used to connect to a vacuum pump or attached to a refrigerant can or tank.
Normal readings on high and low side with AC OFF (static pressure) - Depends on outside temperature, but normally is between 80-105 PSI
Normal low side reading with AC on high speed and MAX & engine at 800-1000 RPM’s - Ranges from 25-35 PSI - Note that on many Chrysler products a normal reading on the low side may be 15-25 PSI
Normal high side reading ranges from 200-350 PSI
Don’t assume that if adding little Freon is good that adding a lot is better!  Overcharging just a little can decrease the performance of the system and possibly damage the compressor.
Both low and high side readings are lower than normal, this indicates a cars AC system is low on refrigerant and is under-charged.
If both low and high side readings are too high, this indicates an overcharged system - too much refrigerant. This also can indicate that the condenser fan is not working, is too slow or the car is overheating and heat is transferring from the radiator to the condenser.
Good luck and hope this helps, keep me posted be glad to answer any question you may have. And yes the A/C system on your car uses R143a and there is a A/C pressure switch along the low pressure line or on the accumulator, it looks like a oil pressure sensor with a two wire lead cliped on it.
Jul 02, 2009 | 1995 Cadillac DeVille
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
70 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
