Question about Kenmore Washing Machines
Front loader washer kenmore
While spinning the whole washer moves around also the tub has little water in tilted towards the back.
  • 15,935 Answers
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
How to drain the inner tub of washing machine
we dont have much call for top loaders in the uk, but if they are like front loaders, there should be a filter at the bottom either on the left or right. if so, pull the machine forward and then tilt it back against the wall. not too far in case it slips forward and lands on its back.
remove the filter cover and then using a bowl and plenty of towels, tilt it forward and let the water run out.
hope this helps
May 12, 2014 | Washing Machines
Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
Washer bangs loudly in middle of spin cycle
Make sure the back spring is still on the back of the tub. That tends to come off sometimes. Check all the other springs while you're down there too. You can balance the unit if you tilt the back side of the washer and then set it back down. it has auto leveling feet. What's happening is once the water is all drained out, the unit will enter the final spin cycle and spin very fast putting the unit off balance so the tub bounces around.
Good luck, let me know if this helped.
Aug 10, 2009 | Kenmore 23012 Top Load Washer
Front loader wont agitate or spin, but it fills with water and pumps water out
likely the lid switch is bad - if not the ECU/timer is.
May 28, 2009 | Kenmore 43042 Front Load Washer
Broken shock absorbers on front loading Kenmore
Hi, first things first. Your model and serial numbers should be on a sticker somewhere around the door opening. Next check the tub. With your finger,push up on the rim of the tub then rotate the tub a few inches and push up again. Continue through a whole rotation. If the tub moves and make a clicking noise you have a bad drum bearing and the cost to repair is more than the unit is worth. If that's not an issue,then it's probably just the shocks,replacing them should solve the problem. Hope that helps.
Mar 21, 2017 | Kenmore Elite 45986 Front Load Washer
Leaking front loader
If your washer has a rubber seal around the inside of the door and it has a little opening where the detergent comes into the washer put your hand inside the rubber piece and feel all the way around and see if you feel any holes or cracks in it and that is where it will leak from.
Dec 03, 2008 | Kenmore Elite 45986 Front Load Washer
Drum Tilt
Your spin basket spider arm support on the back of the spin basket is broken. The spider arms support the entire weight of the basket and insert into the tub bearing in the back of the washer. You will need to replace the spin basket (stainless steel tub) in order to fix this problem. The tub is not repairable and cannot be welded, either (I have been asked this question before). I would not recommend you use the washer any longer as it will cause further damage to the outer tub shells. If you have a repairman perform this job, it can be quite expensive (around $300, $400, perhaps higher), because of the labor involved. Some smaller appliance repair companies won't touch a job like this. However, the washer is repairable, and you can perform this yourself. If you wish to accomplish this on your own, I can give you step-by-step instructions and where to order a new tub. Let me know if you want my assistance.
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Front loader vibrates and moves
You shd check the front legs - they shd be a maximum screwed up, that is the machine shd be tilting forwards. Then you adjust acccording to your floor level. The machine should not shake a bit when off, & you try to shake it with both your hands.
A little vibration is normal when the spin starts. Don't forget to rate me nice............
May 24, 2008 | Kenmore 46462 Front Load Washer
Kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Mar 30, 2008 | Washing Machines
The water is not being pumped out of my kenmore front loader washeer machine
Unplug the washer from AC
Open the bottom access panel (3 screws on bottom lip)
open the large filter in center,
be ready for a lot of water, mops and rags ready. water vac is really handy .
Clean all the debris you find in the filter, reach in an spin the little propeller and make sure it spins freely.
pour in a cup of water inside the tub does it drain down freely.
reassemble and test.
front access panel has a switch so it has to be closed back.
Jan 26, 2008 | Kenmore 43142 Front Load Washer
Washing Machines Logo
37 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
