Question about Eiki LC-XE10 Projector Multimedia Projector
My eiki LC-xnb4m will power on but shuts off after about 60 seconds. It doesn't shut off completely.it just drops the input signal (audio and video) and the fan kicks on heavy for a few minutes. Then thereday light pops back on and it works for 60 more seconds....Solution?
  • 2,237 Answers
May be overheating. blow out the projector with canned air. the dust keeps in the heat that the projector is trying to expell. also check the lamp for bulges and dark spots. if you have any of those, replace the lamp. if the lamp is new, check the colorwheel for a high-pitched whir. if you don't hear it, replace the colorwheel. otherwise, replace the ballast.
Posted on Nov 18, 2009
The projector shuts off after running 60-90 seconds
The air flow might be clogged. This is REAL common on projectors and before replacing anything, you should make sure it is clean inside.
Oct 15, 2014 | Eiki LC-XB23 Projector
Video is reporting No Signal
check the menu for proper video input signal type.
or system , like AUTO, PAL or NTSC
Mar 02, 2013 | Eiki LC-X50M Projector
My church has an EIKI LC-X986 projector that turns on for about 2 seconds then shuts down. The lamp is brand new and the filters are clean. I know the signal is working as I can see it for those 2...
Have a close look at the fan and check if there is a make and model number on it.
If you cant see anything, unscrew the fan and check on the hidden sides.
see what voltage it is. ie 12v dc or 24v dc
Ring the EIKI agent and ask them how much for a replacement rear fan, the EIKI part number, and also if they can supply the manufacturer of it and their part number.
Check that the fan connector is OK, and the socket where it plugs in.
Check that the fan turns freely.
report back what you find
Mar 24, 2011 | Eiki LC-X986 Projector
Fan will not turn off after lamp cools down. fan will run for days.
is this after auto shut down ? check menu setting if this is set to READY, then it will wait until signal appears again at the input. You can set this better to "shut down", PJ will go to standby after cooling period and fans will stop.
Nov 10, 2010 | Eiki LC-X50M Projector
Can't hook up my laptop to play DVD's through my Eiki LC-XNB4M
computer should always be connected with 15 pin VGA to DVI-I cable.
Select in menu input 1 analog RGB and adjust output resolution of Dell to 1024 x 768. this should work !
USB is only for mouse control with pj remote
Jul 09, 2010 | Eiki LC-SM4 Multimedia Projector
In few minutes after turn on the projector (Eiki Lc-xnb4m) , it shut off automaticlly. and i connect notebook with the projector ,no any reaction. i don't know how to operate it?
are any of the leds flashing? could be overheating. blow out the dust with canned air. if the lamp is old, it could be that it needs to be replaced. if the fans go out immediately as well, it could be the power supply.
Aug 22, 2009 | Eiki LC-XE10 Projector Multimedia...
I have an Eiki LC XBN4 that starts and then shuts down within a few seconds
check the lamp for black spots and bulges. if you have any, replace it. if not, you have a ballast/power supply issue.
Jun 24, 2009 | Eiki LC XNB4 LCD Projector
EIKI LC-XNB3 Projector - Does not recognize any Video Inputs
there might be a bad connection between the input board and the main board. There are different connectors ( white) between them, that might be damaged during portable use
May 24, 2009 | Eiki LC XNB3 Multimedia Projector
Eiki LC-xnb4m computer connection issue
I actually fixed it myself--I found another site that said for Dell systems, you need to hold down the Fn button (bottom left) and push F8 and then it recognizes the projector. Solved the problem immediately!
Jan 27, 2008 | Office Equipment & Supplies
Eiki LC-XE10 Projector Multimedia Projector Logo
579 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
neOen
Level 1 Expert
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
