Question about Kenmore HE2 Plus Front Load Washer
Leaking Kenmore "Front Load" 4THE
My washer is 3 years old. The water rushes out the front during the filling and spinning cycle. It appears the water leaks (around the door) when the water level is at the bottom of the door (approximately 1/4 during spinning).
  • 749 Answers
Any error codes displayed?
Posted on Jul 01, 2009
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
My whirlpool 9150 washer has worked well for past 3 years. All of a sudden we've had two intermittent floodings over our floor. Appears that unit is leaking somewher under the front door during spin cycle...
I had the same problem with my Kenmore washer. It was a broken valve that allowed the water to keep filling into the machine. When the water filled high enough, it started coming out of the door. It would have cost over $200 with parts & labor. The tech told me to shut the water off with the lever at the wall after each use. He said you should do this anyway. I didn't have it fixed. I just shut the water off. Hope this helps. LB
Dec 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
White flakes in circular pattern under washer of 7 years. Time to replace?
First we started hearing a grinding sound during the spin cycle. My husband replaced the belt, which was loose and not helping the spinning of the tub any, thus much wetter clothing after spin cycle. The belt gave us another week of use out of the machine and did drain the tub better, but then water started leaking into the tub from the water inlet (or area where water rushes in to fill tub), and was not up to the usual "rush" of water, when filling up. The grinding sound started again during the spin cycle, and so now we are assuming it is the ball bearings or the brakes and perhaps the water pump as well. Estimates for these jobs on the boards seems to run from $400-500.00. The machine is only 7 years old, but after reading so many posts, maybe I should count my blessings that it lasted that long! This was an all mechanical machine, which I loved. Atlantis Maytag, a very sturdy and solid looking machine. Never did really clean that well though. SOLUTION: we are getting a new machine.
Jun 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore HE 3t started leaking from the side when filling
check dispencer and make sure its not cracked,,if not turn your water pressure down to the dispencer its splashing up and over running down..keep me posted onthejob
Jan 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore top load washer approx. 10 years old
f7686aa.jpgPump is leaking around the drive shaft.
To get to the pump CLICK HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Kenmore 44832200 banging during spin cycle
The support spring beside the spinning hausing are cut replace w/new spring available appliances store. bring sample.
Jan 07, 2008 | Kenmore 44832 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
112 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
