Question about Marantz SR-19 Receiver
All I want to do is run an extra set of speakers for outdoor use. I want to be able to listen to the same music indoors and out. Is this possible without separate amp?
  • fmac954 Jul 01, 2009
    How do I hook up speakers?
  • 11,896 Answers
Yes definatly. The speakers farthest away will be a little quiter but will still be plenty loud enough to hear and enjoy.
Posted on Jul 01, 2009
A/C Unit SAMSUNG -Outdoor unit model= MH080FXCA 4A was connected to 3 indoor units:
It's possible you have a bad data wire on one of the systems. Swap the data wire or both if two with a different wire. (1&4--2&3) whatever. Whatever you do inside obviously do outside. Might have extra resistamce that is throwing the error but will be fine for a ground wire.Or do one system at a time, being sure to change your dip switch settings until you figure out the problem unit. Good Luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 19, 2017 | Samsung Heating & Cooling
Have outdoor speakers but will not play sound, they are connected to a xantech pa1235x and the indoor speakers work but not the outside ones
Check the reciever and verify if you have a selector swicth pressed for A speakers and B speakers and see if this helps...
Some recievers will only power A or B, not both at the same time.
Lets not assume your outdoor speakers work. Would be helpful to know if you have tried to disconnect the inside set and plugged the outside speakers in those stereo jacks. If no sound, your speakers may have loose wires on the inside of the box/cabinet/case or they could be no good period.
If they do work, and the system does not provide all four jacks to be powered at the same time. You may consider buying a pair of piggy back rca jacks. Plug in the indoor and outdoor speakers into the same connectors the indoor ones are on now.
That way at least you can run them all at the same time from the speaker connector where you have the indoor speakers hooked up..
Hopefully you'll find something useful in this
Good Luck
Respectfully
Jun 09, 2011 | JBL N24AWIIBLK Speaker
Is it possible to connect my PC to my outdoor speakers? I want to play music outside using my PC. Is there a special connector that I need?
There are a couple of ways to go about this. The first would be to locate a similar computer speaker system set up outside - provide power and extend the cable to them - if not too far. When you want to listen to the outside speakers, plug the cable into the headphone jack of the computer. Adjust volume and enjoy.
Another way, would be to buy (or build from kit form) a low power FM transmitter. These devices are available in mono & stereo types and will play over all FM radios and stereos in a 50 to 300+ foot radius (depending on antenna, wall construction, transmitter power, etc.) when they are tuned to the transmitter frequency. These can be found for under $100 or built for as little as $30 or so. The upside to this method is that the music is available over ALL radios nearby.
Still another way is a wireless speaker system. This works like the FM transmitter, but will only work on these particular speakers. These will require power only - but some will work from internal batteries as well as AC power. The system includes a small transmitter, power cord & cable to plug into a headphone jack - all for use at the computer, and two speakers - each with a power cord as well and possibly a remote control.
Use of a spare pair of old stereo speakers will probably not work as the computer's sound card rarely develops more than a watt or two - and most home speakers require 10 or more watts to be driven properly.
Sep 18, 2009 | Bose Indoor/Outdoor Speakers (Pair) -...
B speaker setup problem
Why don't you set it Zone 2 then you could listen to the radio outside and still watch tv inside. You can turn it on and off just like a and b speakers.
Jul 07, 2009 | Yamaha RX-V663 Receiver
EXTRA SET SPEAKERS
Look on the back of the receiver where the existing speaker wires are connected. There should be some jacks there to connect 2 more speakers. There are 2 wires per speaker, put one in the red and one in the black. Some receivers have a button to turn on/off the extra speakers so make sure it is turned on if you have one.
Jul 06, 2009 | Marantz SR-19 Receiver
Connecting an outdoor MP3 player to an NAD C352 Amp
you could get a bluetooth dock and cables or just get a saeltech bluetooth speaker and run it off your computer .It will let you run your i tunes or media player and go thru your playlist or artist songlisting can also be operated remotely on the speaker unit ! Volume And tracks!!! swamp ratt!!! AAEE!!!!
Jun 02, 2009 | NAD C352 2-Channel Amplifier
What is the correct speaker connection configuration for 5.1 surround and 4 outdoor speakers for stereo music?
Use a speaker switch box but amp may switch off at higher volumes.
Hope this helps.
CABLE GUY.
Apr 19, 2009 | Audio Players & Recorders
Cylinder Like Sharper Image Indoor/Outdoor Wireless Speakers
ask google or you tube or go to car toys they can help. good luck
May 18, 2017 | Sharper Image SR277 Speaker
2 zone setup
Consult the user manual. If you don't have one, it can be downloaded free at Denon's website. Two of the speaker oututs serve multiple functions. Hookup and setup need to be checked. What you want to do is possible as long as you're only using a 5.1 setup indoors.
Sep 02, 2007 | Denon AVR-1507 Receiver
Marantz SR-19 Receiver Logo
74 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
