Why does my Beko WMB 61631s washing machine not work? it tries to start the cycle but then stops and tries to go again every 2 minutes or so?
SOURCE: Error message when trying to wash
Unplug the machine and spun the drum few times by hand, wait 10-15 min. and plug it back. Good luck!
SOURCE: beko washing machine
replace the timer not sure where you will get a service book from replace one wire at a time when you change the timer.
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
SOURCE: nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
SOURCE: Beko wma1510s washing machine dial problem
my beko wma 1510s will not spin and is heating up
