Question about Metra 70 1736 Hyundai 1986 91
The cable that pulls up and down the window has
Hyundai accent, the cable that pulls up and down my electric window has wrapped round the plastic cog and now it completely stuck. Do i have to buy a new one or is there a way og taking the plastic cog out/
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 94 Answers
The window regulator will need to be replaced. Then this happens the cable gets tangled up in itself and damaged. I have never been able to sucessfully repair a regulator when this happens.
Posted on Jul 03, 2009
2002 Hyundai Accent GL. Back power window won't roll up. Can hear window motor working.
needs new lift assembly made of cable on plastic pullys and its worn out
May 19, 2011 | Hyundai Accent Cars & Trucks
2002 Hyundai Accent electric window problem - the passenger side window glass doesnt go up or down. The window motor still works
You have a broken window regulator. It looks similar to the picture below. The pplastic guides fro the cables break and cause the cables to just "pop" and "crunch" , but the window won't move. DORMAN makes aftermarket replacements for all of the doors in your vehicle. (they are all different) They are avilable at many parts distributors including CarQuest and AutoZone.
Feb 05, 2011 | 2002 Hyundai Accent
I can not find the location of the spark plugs on my 2006 hyundai accent
Have you removed the plastic cover wrapped around the engine?
Nov 12, 2010 | 2006 Hyundai Accent
How do i repair the windshield wiper control?
it may have snapped a tooth on the plastic cog inside the unit itself, if so the whole unit may need replacing, it just as costly trying to replace the cog itself and can sometimes snap the teeth again.
Jun 21, 2010 | 2008 Hyundai Accent
HOW TO REPLACE DOME LIGHT BULB HYUNDAI ACCENT 2002?
use a small screwdriver to pull down the edge of the plastic cover, once the cover is off. Slide out one end of the bulb and the following other side.
May 16, 2010 | 2002 Hyundai Accent
2002 hyundai accent DL sedan. my tension pulley
hi from uk to retime cambelt is as follows = the crank cog has a mark which lines up with corresponding mark on front of engine block mark is approx 12-30 o/clock this is TDC No 1 the the cam cog has a small drilled hole in one of the webs just below the cog teeth ? this hole has to be at 12-o/clock position and then using a small mirror if you look through this hole you will see a vertical notch on the front of block this is theTDC mark for cam you then fit belt anticlockwise from c/shaft to cam then round tensioner then release tensionor to tension belt and then lock it up torque both bolts 20 - 27Nm rotate engine manually 4 complete turns clockwise then recheck marks ok /re align ? then re assemble crank pully bolt torque is 140 -150 Nm may i just inform you? that your engine is what is known as interferance that is to say in event of c/belt failure there is more than likely valves to piston contact however this can also occure too if miss timed belt fitted and engine has tried to start ? a compression test on cylinders will confirm if this has happened or not ? hope this helps
Mar 16, 2010 | 2001 Hyundai Accent
My sons's 2002 accent passenger wiper is not operating correctly. It looks like it isn't securely mounted and is waddling in the hole
It could be these bolts came loose or the shaft that goes thru the bushing is shot. 4b964c8.jpg Here is a view from underneatha7dea07.jpg to get into here, remove the 14mm nuts that secure the wipers to the shafts, remove the wiper arms, and there are these little round plastic fasteners that hold the plastic panels on, to remove them push the center pin in just a little bit and they will pull out, they may break depending on how brittle they are, but they arent expensive7784f1c.jpg Hope this helps.
Jan 19, 2010 | 2002 Hyundai Accent
Removing door panel on 1997 Hyundai Accent
Look under the round part of the handle,see if there is a small allen screw there,if it is unscrew it until the handle comes off.if not send a new message
Sep 06, 2009 | 1997 Hyundai Accent
How to replace a window cable on hyundai accent
I use to have a Hyundai Pony once, there was no cable there.
But still you need to remove the inside cover etc. to get there.
I became an expert blindfolded and a hyunday hater afterwards.
Apr 14, 2009 | Hyundai Motor 1998 Accent
Door Handle
put thin piece of cloth between window crank, twist it around, turn window crank up and down, then pull thin piece of cloth away from the round spinable crank ball (piece you hold) this shud remove interior hidden C clip. try again if you dont succeed. those tools they sell wont fit and will scratch the door panel. I am having probs in removing the door handle and lock mechanism... removed screw, yet still attched. grrrr
Feb 04, 2009 | 2002 Hyundai Accent
Metra 70 1736 Hyundai 1986 91 Logo
244 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
