I have a Bosch Dishwasher SHU9915. No water will enter the dishwasher I have replaced the water valve and still no luck. What is the next step. There are no water flow issues. I have an older Bosch, a SMU4052 model. It's been for 13 years, but has stopped taking in water. I think this was a gradual problem as we did notice in the past month that it wasn't cleaning as well. A very small amount of water is coming thru, but neglible now. The copper pipe leading from the valve into the dishwasher is not getting hot, so I'm wondering if the problem is right at the valve. The pipe before the valve does get hot when I run the hot water in the sink. The valve is in a place where the pipe forms a sharp elbow. Should we replace the valve? Or if it's a buildup of sediment, is there an easy way to clear it? I also checked the pipe where it enters the dishwasher at the bottom front and it is also cold to the touch.
-   My Kenmore has been great, but the other day I set it to wash and went to work. When I returned I opened and noticed the soap was sloped down the door and dry. The dishes had not washed. I thought I may have forgot to push the "start." Well, it wasn't me. I tried again and noticed it wasn't filling with water, only a small amount of water was going in to the washer. How do I fix the problem?-   dsawaya
Hi I use a wqp8-9239as dishwasher and I have a problem. the wash light is blinking and the process...
(More)
Hi I use a wqp8-9239as dishwasher and I have a problem. the wash light is blinking and the process to finish the program is stoped. Im not able to reset the program. What can I do. Thanks
E1 Fault on Kenwood kdw12st3a? Help please: I have a brand new Kenwood KDW12ST3A, we emigrated to...
(More)
E1 Fault on Kenwood kdw12st3a? Help please: I have a brand new Kenwood KDW12ST3A, we emigrated to Australia and took it with us. We have never used the unit but when we arrived and plumbed it in it shows E1 fault. I have tested water inlet pressure and its ok. The unit fills and empties three times then faults. The wash pump never starts during this cycle. Any help would be greatly apprieciated thanks
