Question about Sony Cyber-shot DSC-N2 Digital Camera
Burn mark on pictures
Ther appears to be a burn mark in all photos although nothing is visible on lens
  • 126 Answers
Bad CCD imager, Most likely unless you repair yourself with a parts camera not worth repairing.
Posted on Jul 02, 2009
When turning the camera on the lens keeps opening and closing then freezing midway, can't take any photos.
check if you can find any obstruction, that blocks the free movement of the lens barrel. If nothing is visible on the outside, perhaps something inside went wrong. (broken gear?)
As long as the camera finds the lens barrel does not go out to the end position, it will try to get the lens in and switch off.
Also try to charge the battery, because an almost empty battery, can do the same. Although after a few times the camera will not start at all.
Dec 29, 2013 | Olympus FE-340 Digital Camera
I got new Sigma 18-200 DC II lens, with Canon EOS 5D Mark II it has black lens frame is visible through viewfinder or on the photo. Does it mean this lens is not compatible with 5DmrkII?
The EOS 50d Mark II is what's known as a "full-frame" camera. Its image sensor is the same size as a frame of 35mm film. The Sigma DC lens is intended for cameras with smaller sensors. The lens is compatible in that it will work with the camera to take pictures, but the pictures are cropped due to the smaller imaging area of the lens.
In order to use the full image sensor area you need to use full-frame lenses. In the case of Sigma, this means lenses without the DC designation.
Aug 03, 2012 | Cameras
5050 burn in problem
bad plasma dispaly panel. Once burn in has occurred there is nothing you can do. Too costly to replace panel.
Nov 27, 2011 | Pioneer PureVision PDP-5050HD 50 in....
Some marks have appeared on my lens and although I have cleaned it they still appear. They look like scars and have no idea how they got there
If they do not show up on the actual pictures, do not worry about them. Being on the lens, they would be so out of focus as to not cause any problems.
Aug 13, 2011 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
My s8000 has got a problem with it.there is no scratch visible. but still a black dot mark is appearing on the fotos.when the zoom is increased,the size of the dot mark decreases. i've cleaned the lens...
This is not something that you can clean from the outside. It is probably on an inside element of the lens, close to the CCD. I would send it back under guarantee, along with some prints of photos showing the mark.
Dec 02, 2010 | Nikon Cameras
A small black dot is visible when we use view finder of the nikon d90, i am sure it not the lens marking. is it a production mistake or some thing stick with the view finder but nothing in out side. It...
Does the dot appear on the pictures? If so, this is a dust particle on the sensor. If not, then it is a particle on the focussing screen and really presents no problem.
Oct 25, 2010 | Cameras
D80 kit 18/135 won't make photos 'F- -' error
Unmount the lens and clean both the camera and lens contacts (the metal strips that connect body with lens) using a pencil eraser. Take care not to let any debris fall into the camera. Mount the lens and try again.
Feb 15, 2009 | Nikon D80 Digital Camera with 18-135mm...
Problem with my JVC GZ-MG130U
I have a problem with no picture with the lens cover open. It seem to record sound but no picture.
It states the lens cover is on but it is open.
Aug 28, 2008 | JVC 580136 Camcorder
White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Jan 19, 2008 | Pentax Optio E10 Digital Camera
Lens opens when turned on but nothing appears in the lcd cannot take pictures
I had that problem and found that plugging it in to my pc and downloading the photos ticking remove photos from camera worked
I think it is because I filled the memory card.
plus the camera charges while attached to pc.
I hope this helps
Jan 22, 2007 | Kodak EasyShare Z650 Digital Camera
Sony Cyber-shot  DSC-N2 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
