Question about Tech Solution TS-2550 Shredder
Tech Solutions Power Shredder Model TS-02
I need a power cord for unit. When I plugged it in the outlet and removed it, one of the prongs came loose.
Please let me know where I can get a replacement a.s.a.p.
  • 168 Answers
SOURCE: No Power!
Check and make sure the paper catch bin is locked into place.
IF the shredder doesn't see that the bin is in place, the shredder will appear dead for safetly reasons.
There is a possibility that the control board was cracked but the only way to check that, is to take it apart and check.
Good luck.
Posted on Feb 07, 2008
SOURCE: Tech Solutions model #TS 5000 Cross-Cut Paper Shredder
Call Tech Solutions at 1-800-639-3803
Posted on Sep 28, 2008
  • 6 Answers
SOURCE: Tech Solution TS-4500 Shredder Problem: Shredder Switch
The phone number 1-800-639-3803 is on the bottom of my TS2550. It is . I called it today and did talk to a help desk person. Basically, they told me that my shredder was manufactured in China and they are only importers.
Hopefully thay can give you more help than they gave me.
- Wes (wcbyers)
Posted on Jan 03, 2009
SOURCE: Tech Solutions shredder Only powers in reverse w/ green light
These are made by Winsource Industries http://www.winsource-hk.com/ The contact information is Hong Kong. I haven't had any luck getting a replacement for one with a Limited Lifetime Warrany.
Good Luck -
Posted on Feb 12, 2009
heatman101
  • 43501 Answers
SOURCE: Where can I get new
Unfortunately there are no replacement parts for many shredders...they are made to throw away when the break...
Stinks... but that's the way it is...
heatman101
Posted on Jun 16, 2011
Lights will not turn on
I experienced the same problem. One day the lights on the unit weren't on. The wall outlet that the dishwasher uses had power because the Garbage Disposal that also uses the same outlet had power. Turns out the power supply cord also tied to the water supply hose and had over the months (due to the constant slapping or dancing of the water hose whenever the electrically controlled water valve was opened or closed), had caused the female receptor prong inside the wall outlet to loose continuity with the male prong of the dishwasher power cord. It might have been a defective wall plug all along but the wall outlet worked for months before the problem arose. Anyway, after replacing the wall outlet the dishwasher again has lights and works fine.
Mar 06, 2015 | KitchenAid Dishwashers
LG DLE2514W Power does not stay on. Power cuts
If you move the cord @ the outlet and the dryer shuts off replace outlet if the prongs on the cord are not damaged.
If you wiggle at the dryer side and it shuts off un plug the dryer remove acess cover and inspect end of cord. Ck. and make sure terminal nuts are tight. and not burnt due to a loose connection.
Jan 12, 2010 | LG DLE2514 Electric Dryer
Their are sensors on top and bottom of cutter asm. Good chance one or more are dirty, blocked with paper shreds or just bad. Clean with compressed air and lightly moistened cotton swab.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 01, 2009 | Tech Solution TS-8000 Cross-Cut Shredder
No power..doesn't turn on
you may have a faulty temp control or there is a wire off around the compressor area cheak the relay on the compressor if it is burned or a wire is shorted out.Hope this helps o and try to give the temp control a tap with somthing some time it will kick on that for sure would be a bad temp control Hope i helped:)
May 20, 2009 | Heating & Cooling
Good Luck -
Jan 25, 2009 | Tech Solution TS-8000 Cross-Cut Shredder
Power transformer broke
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Jan 05, 2009 | Tech Solution TS-4500 Shredder
TS-6000 Shredder Problem
1800 639 3803 tech solutions service hot line for the ts6000
Aug 18, 2008 | Tech Solution TS-6000 Shredder
my power cord seems to have overheated and the prongs won't stay out when plugged in. How do I purchase a new cord and how much does it cost?
Apr 20, 2008 | Tech Solution Office Equipment & Supplies
No Power!
Good luck.
Jan 06, 2008 | Tech Solution TS-4500 Shredder
Tech Solution TS-2550 Shredder Logo
197 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Marvin
Marvin
Michael Galve
Michael Galve
quennie732
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
