Here is the steps to change the language to english
>Select Wrench or setup button on the front panel
>Press the Right arrow button 4 times
>press ok to select language
>press ok once again to select english
Please follow the above steps carefully it is very simple i am sure you can do it.
I work for HP but my posts and replies are my own.
Click the Kudos star as a way to say "thank you" for helpful posts.
Be sure to come back and click the 'Accept as Solution' button on the post that solved your issue - it may help someone else .....
SOURCE: HP Laserjet 3030 printer/scanner/fax Language has
How can i change HP laser jet 3030 printer's language?
SOURCE: CHANGING PRINTER CONTROL PANEL LANGUAGE
See solution below:
1. Turn off the printer.
2. Press 'select' and turn on the printer. (select button should be pressed while turning it on)
3. press '-value+' to choose your language
4. press 'select' to save
5. press 'go' to return to ready mode.
Thanks
SOURCE: Back to english.
Press the Home button. Wait about 5 seconds then select the Device Settins icon and press OK. Press the right arrow and press OK. Press the down arrow 4 times (5 if you have the bluetooth module installed) and press OK. Use the up and down arrows to select English and press OK.
SOURCE: change language
Follow these steps to resolve the issue.
1. Unplug the power cord from the back of the product.
2. Press and hold the Cancel and Color Copy buttons simultaneously on the control panel.(My color button was the green button)
3. While still pressing the buttons, reconnect the power cord to the back of the product.
4. Continue pressing the buttons until the display goes blank or Reset shows on the control panel display.
5. If the product automatically turns off, turn it on.
6. When prompted, select the correct language and country/region, and then press the OK button. Press the OK button again to confirm the selection.
NOTE: Some products might have a promotional sticker on the control panel display. Make sure that any stickers are removed from the control panel display before troubleshooting this issue.
If you have completed all the steps listed above and are still experiencing a problem, service the product.
These directions were copied from the following url:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01368025&cc=us&lc=en&dlc=en&product=3192753&tmp_track_link=ot_search
Solution
SOURCE: change the language on hp
For the LJ4000 to change the control panel language:
On the front panel, hold down the SELECT key.
Turn the printer on, while continuing to hold the SELECT key.
When the Select Language message is displayed release the SELECT key.
Initializing will display on the control panel. After 5-7 seconds Language=English will display.
Press the VALUE key until the desired language is displayed.
Press the SELECT key and an asterisk will appear. The asterisk indicates that the printer has saved the new setting.
Press the GO key to display Ready in the language that was selected.
NOTE: If Select Language does not appear in the display, hold down the SELECT button until you hear the motors rotate, then release. Following printer initialization, the Language= menu will appear in the display.
hope it helps, if so do rate the solution
