Question about LeapFrog Leapster Electronic Book: Spider-Man (30425) for PC, Mac
String broke on attached stylus
How does the pen come appart to re-attach the string inside the head of the pen.
  • 258 Answers
There should be screws holding it together, if not there will be a way to pry the casing apart, hope this helps you
Posted on Jul 01, 2009
How do I get the trimmer head open?
Turn the knob in the middle of the head anti clockwise and the string reel should come out.
Aug 21, 2015 | Garden
Would like a parts schematic for a Bb400 gold tone bass banjo
This is a list of All the parts you need, I don't know about a schematic?
1 Maple Neck ? 1 11" wood rim ? 1 11" notched tension hoop ? 1 Flat head alloy tone ring (Optional bell brass available) ? 1 Resonator (not included in the open back kit) ? 1 11" Remo frosted banjo head ? 1 Arm Rest ? 2 Coordinator rods with hanger bolts (one longer than the other) ? 1 "L" shaped tailpiece bracket (may be attached to coordinator rods) ? 1 5th string nut ? 4 Guitar style tuners (planetary tuners optional) ? 1 Geared 5th string tuning machines ? 24 Shoe style lugs with bolts and washers ? 24 Hooks and nuts ? 1 Nut, pre notched ? 4 Resonator plates ? 4 Brass inserts (brass anchors that are threaded on the inside) ? 4 Resonator bolts (knurled on the outside with a Phillips screwdriver receiver on top) ? 1 5 string bridge ? 1 Gary Price style Tailpiece ? 1 Set of strings ? 22 Pre-cut (ready to install) frets ? 1 Truss rod cover (including three screws)
Mar 06, 2015 | Bass Music
I purchased an 8 inch heavy-duty brushcutter blade for my Ryobi 30 cc four cycle powerhead how do I attach it to the string trimmer head
You can't use the blade on most string trimmers unless you have a brush cutter style then you would unscrew the trimmer string head and attach the blade with the adapter that came with the unit.
Oct 23, 2014 | Garden
Strings slip
That is a discontinued model.
Check which way it is losing tuning. If from the machine heads, very unusual, try an extra turn on the tuning bar. If the string is slipping at the bridge end, check the fitting of the strings.
If you make a mark with a felt tip pen on the 12th fret position on the string, see which way it moves.
Dec 07, 2017 | Taylor Leo Kottke Signature Model Guitar...
The weedeater string part below the Gaurd fell off I disconected the shaft and put the blower attachment on and it works fine. Is it the string head that's bad or the inside cable orthe coplete...
The part below the guard is designed to come off for cleaning and restringing, as long as you still have all the parts, you just need to put it back together and it will be fine.
Jun 30, 2011 | Garden
HOW DO I INSTALL A NEW STRING IN A PRO CUT 11 for Ryobi RLT30CD trimmer
LINE REPLACEMENT (Fig. 8) (For Reel EasyTM Head) Use 2.4mm monofilament string. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Cut one piece of string approximately 7.6m in length. n Rotate knob on string head until line on knob aligns with arrows on top of string head. n Insert one end of string into eyelet located on the side of the string head and push until string comes out through eyelet on the other side. Continue to push string through the string head until the middle section of the string is inside the string head and string outside the string head is evenly divided on each side. n Rotate the knob counterclockwise on the string head to wind the string. Wind the string until approximately 20cm remains protruding from the string head. INSTALLING STRING IN PRO CUT II STRING HEAD Use monofilament string between 2.4 mm and 2.7 mm diameter. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Gather two of the pre-cut lengths of trimmer line provided or cut two pieces of trimmer line, in 28 cm lengths. n Insert the strings into the slots located on the sides of the string head. String should be pushed in until approximately 2 cm protrudes from the holes on the top of the string head. n Remove old string by pulling it from the holes located on the top of the string head. http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Oct 29, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Need help restringing it
For starters, if you don't have the original, in-the-box trimmer thread, you should get the appropriate diameter. Ez enough, you just need .9 to .10 diameter thread are somewhere around that diameter.
Which attachment are you trying to restring, there are several. One will have holes for a "fixed string" with a label that says "stop" on it. This is the fixed string attachment head. Take a piece of fix string, these are pieces of precut string that come with various other tidbits in the box, about 10-12 inches long. insert the string through the head the inserted end comes out the other side. Pull that end out to the edge of the "stop" label. Repeat the process for the metal hole on the other side. That's it, now you are ready to go.
The other trimmer head is a bit more difficult. Unscrew the top sleeve to expose the bare, 2 chambered core - have replacement or original thread ready to go (same diameter as mentioned previously). Once you have removed the top, notice that there are two holes with notches in between the 2 thread chambers. The notches will indicate which chamber you will be sending the thread that will be coming through the holes. Have the thread ready to go, and insert one end all the way through the hole on one side and then out the other. Now you must get the string ends coming out more-or-less equidistant from the two attachment holes so that you get an equal balance of thread being fed out of the head - either with helper holding the attachment head or by just hooking the attachment head around a pole or something, pull the 2 threads through to get them equidistant.
Once you've done this, follow the notches at the respective holes to wind the thread into the proper chamber, as if it were fishing line. Finally, put the head sleeve back
For the other trimmer head
Aug 18, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do I get the head off of the trimmer?
There should be a round knob at the bottom of the spool where the string is. Twist off counter clockwise and the spool of string will drop off.
Jim
Jun 20, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Require Manual for Ryobi PTL 2543 25cc line trimmer
Or sometimes you unscrew a retaining bolt set into a plastic "lug", the spool drops out, refill t with line, replace it putting line through holes in the spool casing, refit the "lug" and tighten it again. I think I have the manual for this though and if so maybe I can send you a link to images on MSN Homepage to help you..
Feb 22, 2009 | Ryobi 15" Electric Factory Reconditioned...
We to hide the string for pen of the hp pavilion tx 2000
There is really no good way of hiding the string. There is a pen you can buy that has a retractable string, but then you have this little box on the side.
Jun 26, 2008 | Computers & Internet
LeapFrog Leapster Electronic Book: Spider-Man (30425) for PC, Mac Logo
235 people viewed this question
Top LeapFrog Computers & Internet Experts
Alun Cox
Michael Cummings
Level 1 Expert
k24674
Are you a LeapFrog Computer and Internet Expert? Answer questions, earn points and help others
