Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Tractor starts then stop running
Model 917.275390 (LT1000) and is about 4 years old. It runs for about 10 minutes (sometimes) and then stops. New battery, spark plug, air filter, fuel filter w/hose, drained tank and have clean gas, oil filter, & coil--all this year. I'm frustrated because I'm now paying to get my lawn mowed when I have a tractor in the garage (covered). I noticed a loose electricalconnector (pink end) but cannot find where it could be connected to. Are any of these wires supposed to be loose?? PLEASE HELP.
  • 11,896 Answers
It will either be the stator that needs changing or the carb needs to be pulled off and cleaned
Posted on Jul 01, 2009
2 Suggested Answers
wadembly
  • 513 Answers
SOURCE: i am looking for owns manual for craftsman lt1000
you can find owner manuals at sears parts direct .com
Posted on Jun 27, 2010
Husqvarna YTH1842 stops running when hot
Try slackening the fuel filer cap, if the breather is blocked in the cap it will vacume and stop the fuel from flowing, if it runs ok with the cap loose replace the cap.
May 18, 2013 | Husqvarna Garden
Engine stops running
if it was a bad gas or water in the gas the car would not start and if it does start it would run really rough it sound to me like you have an over heating problem doe s the temp gauge say its over heating just before it dies?
Oct 01, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My cub cadet stops running 5-10 minuts
check the bowl for dirt or try putting in some stable
Jul 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Instructions for fixing the choke on a Craftsman LT-1000 lawn tra
I have been hearing alot of this problem. Well it is gravity flow. I just bought a 2002 lt1000 17 hp without a carb the guy was having the same problem so he sent the carb away to get checked out and low and behold it got lost. He waited the summer to see if it would show up but it did not. He got mad and bought a new bigger one. Any ways i am waiting on a new one. Now in my reading these problems i discovered that the fuel line coming out of the tank to the carb is lower. Might be somthing to look at. JIM
May 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Our new to us john deere 345 tractor won't keep running
You may try blowing backwards from behind the fuel filter into the gas line. Not to much air pressure though. Make sure the gas cap is off.
Mar 13, 2010 | John Deere A,b,g Tractor Carburetor Float...
The engine runs and then stops after running. I wait and then it starts and runs again for about 1 minute and then stops again.
I have a old 2010 Diesel did the same. It was the fuel return line from the pump to the fuel tank. It's a short ? 10" long line.
Replaced it, now it runs for ever.
Barry
Jul 12, 2009 | John Deere 420,1020,2010,2020,2510,2520...
This sounds too easy of a solution but I had a like ptroblem with my Craftsman. I loosed the gas cap a bit and the rough running and stalling stopped. he vent on the gas cap that contains a turn over interrupt valve was plugged causing the gas not to flow. I took the cap apart and cleaned out the vent hole though cleaning the holewith a paper clip would have worked as well. Anyway..it fixed my problem. I think my dirty hands of deris deposited the matera in the vent hole when filling with gas.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
19.5 HP brggs engine (craftsman) shuts down after long runs.
Sounds like the coil,pull the shutoff wire off the coil and try it.if you still dont have spark replace coil.
Mar 17, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Heater runs hot for a few minutes then stops heating
I would say from what you have described your problem is a bad thermostat heat sensor (you may have to replace the whole thermostat on this model!) This is a very common problem for this unit!
Please rate my sesponse!
THANK YOU
Jan 14, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
446 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
