Question about Maytag Atlantis MAV6000 Top Load Washer
My top loading neptune is giving me an error code op but the door is shut...any suggestions
    Sergeant:
  • 353 Answers
Door switch is broken or the pin on the door is broke off
Posted on Jul 01, 2009
I am getting error code ll trying to find out if it is worth paying somebody to fix it Describe your Neptune FAV6800AW Top Load Washer Problem
If it a FAV6800A or FAV9800A I can..........What is the error code.......DC, UC OD, OP? Is the machine banging around in spin cycle of the wash cycle. Be as detailed as you can with the problem description.
How handy are you or do you? Do you know someone that has basic mech. skill sets and can help you?
Aug 24, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have an OP message on my Maytag washer FAV6800A/FAV9800A . The washer is not locked I can open the lead ...when I close the lid and start the washer the OP error comes up. Any help will be...
If you get no help at this forum Google This ""Neptune TL Washer FAV6800AWW""
5th post down you will find the SM and support for the "OP" error code. You have lost signaling thru the Left Hand Lid Lock............DH1200s
Aug 21, 2011 | Maytag Neptune FAV6800AW Top Load Washer
It says lid is open but its not
You have lost signaling thru the lefthand lid lock
Google this "Sticky: Neptune TL Washer FAV6800AWW"
Go to the 5 post in the sticky for the Service Manual and within the Sticky I describe the issue of OP, OD, and FL error codes.
Ypu don't mention in your description but I assume your machine is throwing an OP or DO error code.
I describe how to diagnosis and repair the issue.
Jan 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag top load washer op error code, washer wont start. Checked and magnet is in place, what else can it be?
If you place a couple magnets over the left gray bumper and the "OP" error code doesn't clear then I feel you have a problem with the Left Hand Lid Lock.
See if this post will help; Left Hand Lid Lock Troubleshooting
Sep 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
MY MAYTAG NEPTUNE MODEL FAV6800AWQ KEEPS DISPLAYING THE LETTERS OP
You have lost signaling thru the Left Hand lid Lock. The washer has not see the lid go closed thru the signaling with the magnetic reed relay in the Left Hand Lid Lock.
You could have a Lid Magnet out of position or severe corrosion. You can place a large magnet over the Left bumper like this and see if the OP error code clears;
See this post for troubleshooting the OP error code Left Hand Lid Lock Troubleshooting I go over OD error code troubleshooting but you troubleshoot the issue the same way for the OP error code.
If the Lid Magnet is not out of position you may have an open circuit thru the Magnetic Reed Relay as shown in the Pics of this link Left Hand Lid Lock Troubleshooting.
The p/n for the Left Hand Lid Lock is 25001048
Some other handy links. The Service Manual for reference. Sears Parts Direct for reference..........Rich
Jun 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune top load. I am getting an od code
Be sure to unplug the washer before attempting any troubleshooting. On the Maytag Neptune the "OP" code indicates a problem at the door switch. These washers have a common problem associated with this code. The door isn't completely waterproof and allows water to get into the area where the lid switch is, corroding the electrical contacts and wires. Use a putty knife or screwdriver to open the top of the machine to access the door locks. Look for any broken or corroded wiring connections and reseat and clean as necessary. Test the switch using a multimeter or ohmmeter. Check for continuity. A lack of continuity will indicate a faulty switch. Sure hope this helped and best wishes.
Sep 10, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune keeps giving us the OP signal
Hello Kristi,
If its FAV6800A/FAV9800A try placing couple 1” dia magnets or similar magnet on the left bumper of the machine and see if that will clear the the “OP” lid open alarm, see pic attached. If that clears the alarm the lid magnet may have moved out of position in the inner lid. See page 33 of the FAV6800A/9800A Service Manual for its location. If that doesn’t clear the “OP” alarm remove 120VAC to the machine and try reseating the left lid lock plug into the left lid lock a few times to possible clear corrosion causing loss of signaling from the left lid lock to the control board Lid Is Closed input. See page 33 and 34 of the SM for pics if the left lid lock and lid magnet. I recommend surge protection on the120VAC outlet powering the machine to help protect the washer control board. Good luck Rich.
Place some external magnets on left bumper and see if that will clear the "OP" alarm.
Try reseating the left lid lock plug into the left lid lock. Be careful, it may be difficult to remove for the 1st time.
Mar 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune OP code
i have the same problem....i fixed it once using the user manual so i know its in there...but i lost mine :(
Jan 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune tl
Code OP means lid is open. If it really isn't, then the problem is with the switch that sense whether the lid is shut or not. Could be bad switch or bad connection.
Jun 06, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
