SOURCE: How do i attach a Wall Mount to the TV?
Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side.
these are for universal mount.
http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp
I think this clears your problem
SOURCE: wall mount hardware
The bolt size you need is: M8-1.25 X 20. 20 is the length that I used and it works well. You could also use 25 (which is a little longer) if you would like. It took about 5 trips to Home Depot and Lowe's and a few hours searching the web before we got it right.
SOURCE: PROTRON STAND
Is that a problem? Check the hole size and choose a screw with a head that is bigger than the hole size. Typically select a minimum of 4mm diameter screw.
I have the same TV, and I bought a mount with 4 connector holes. I was able to connect 3 of the 4 and it has been fine as the TV does not weigh too much. The TV was not designed with the current mode of either wall or stand mount. It was just intended for stand. I have had it on the wall for over 2 years.
SOURCE: LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Testimonial: "Thank you! We'll head to Lowe's tomorrow to pick up the appropriate size screws. We just moved into a new home and they left the wall mount up for us, but did not leave any of the extra screws that went with the mount. Thanks again! "
