Question about Maxi-Cosi Foray Trail Stroller
Where can I find replacement parts? Like wheels? Ours is less then a year old, and the break broke even before we used it, and the front wheel fell off yesterday.
How would i fix the control wheel on my center vent for my 2000 vw new beetle 1.8 turbo
You will have to go to a dealer for this. Also there is a chance that you wont be able to find it because it is 10 plus years old. Manufacturers are not required to supply parts for vehicles that are over 10 years old. You may want to try a salvage yard too. Also there is EBAY. Best of luck.
Jul 17, 2014 | Hardware & Accessories
Front wheels making growling noise and try to lock up when put in four wheel drive
first question we ask is this. are all 4 tires the same diameter??? if two are newer than the other two it will do as you describe. also if you are trying to drive it in 4 wheel on dry pavement dont. youll break things to dont want to know about and they are expensive.
Feb 01, 2018 | Chevrolet Silverado Cars & Trucks
Top of front passenger wheel fell inward .what
likely the upper ball joint, but could also be the structure that holds the joint.
Dec 31, 2009 | 2000 Dodge Durango
1995 Olds Sillohete Front wheel fell off. Trans
i am not really sure if it was me i be calling all of the good salvage yard around give this website a try to help find something close to you www.junkyarddog.com i also would like to give you this information they sell only GM-parts its Schram auto & truck parts 1-800-292-1032 and they website is www.schramauto.com wish you the best of luck Michigan Man.
Nov 02, 2009 | 1995 Oldsmobile Silhouette
Kenmore dryer 110.76732500 problem
I would take a hammer and hit it hard break it off I have done this a hundred times at my shop then you can put new blade on with ease
Apr 02, 2008 | Kenmore 75944 Gas Dryer
GRACO STROLLER FRONT WHEEL BROKEN
I have the same problem, the airline broke ours the last time we flew. I just found on Graco's website that you can order replacement parts. Here is the link, http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11
You'll need the model number and serial number. I found ours on a sticker under the footrest. For our stroller it's $19 plus shipping for the front wheel assembly.
Hope this helps.
Jan 13, 2008 | Baby Gear
Maxi-Cosi Foray Trail Stroller Logo
193 people viewed this question
Top Maxi-Cosi Baby Gear Experts
ray gallant
Douglas Dinnebeil
Douglas Dinnebeil
Marc Cohen CPSTI
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
