Question about Whirlpool Duet GHW9150P Front Load Washer
GHW9300PW/Dove Grey on White - Whirlpool® Duet® Ultra Capacity Plus Washer
This machine won't start. Power plug / all the buttons are OK. but when I try to start it doesn't start. The Switch which gets locked once you close the door is OK.
Please help
  • 249 Answers
Re: GHW9300PW/Dove Grey on White - Whirlpool® Duet® Ultra...
Are you sure about the door switch, thats all I think it can be.any lights on ?
Posted on Dec 08, 2007
0 characters
3 Points
Control lock lit, no other buttons work
    • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
    • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
    • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
Read more: How to Unlock the Control on a Whirlpool Duet '
Jan 09, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Need to reset a whirlpool duet washer
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer had an off balance load. the load stopped with 45 min. to go and we can't restart
unplug from wall for a min plug back in and push power on select drain/spin then the start button
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I receive an f 02 error on delicate cycel and it won't finish the load
Error F 02 means the drain time is taking longer period then normal. If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is flashed. To resolve the issue you are facing with you need to follow these steps---
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the ‘sud’ error will be displayed, then 4 minutes later the F/02 error code will be displayed.
To clear this error code—
Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
If still the error code exists then you need to replace the pump.
Thanks for using FixYa and revert for further assistance.
Jul 19, 2009 | Whirlpool Duet 4.0 Cu. Ft. 14-Cycle Ultra...
Duet Washing Machine model ghw9100lw1 FH ERROR CODE
you should here a humming noise, just before water comes in .do you?close eire let me know.
Dec 07, 2007 | Whirlpool Laundry 27'' Duet Ultra Capacity...
Whirlpool Duet GHW9150P Front Load Washer Logo
177 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
