Question about Kenmore Washing Machines
Kenmore HE5t f21 error code
Help
  • 15,935 Answers
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 11, 2010
4 Suggested Answers
  • 272 Answers
SOURCE: Error code F21 - thanks for your help
The F21 error code is an indication that the unit has too long of a drain out condition. If the control calls for the unit to drain & the water does not drain out in 8 minutes or less the unit will stop & flash the F21 error code. I would recommend checking the drain pump & pressure switch circuit.
Clear pump of debris. Tilt machine. Take off front panel. Unscrew large white drain plug. Remove debris.
Unplug from power source...remove front lower panel (3 sheet metal screw wirh 1/4" drive head located on the lower lop of the panel)...open pump strainer (looks like a large stove knob, Turn it counter clokwise, lookout! lots of water will gush out... back flush the pump by filling the outet of the drain hose ( this may dislodge debris that may jam your pump)...re-assemble, plug to power, and turn-on. That will help get rid off the debris.
It can be done if you are patient and able to figure out how the plastic thing comes apart. Good luck!
Posted on May 09, 2009
blueextc3221
  • 15935 Answers
SOURCE: HE5t washing machine flashes F35
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
  • 91 Answers
SOURCE: kenmore elite washer he5t error
remove bottom panel 3 screws 7mm get bucket and alot towels, turn pump filter clockwise and remove all debris from inside pump now close it up nice and tight should solve youre problem
Posted on Jan 04, 2009
I watched pornn on my moms computer and i can't clear history!!!!
Don't watch stuff you aren't supposed to watch in the first place.
Apr 09, 2017 | Polaroid PMP120-4 4GB USB 2.0 MP3 Digital...
Can apple cider vinegar get rid of skin tags
The answer is yes. Apple cider vinegar can help you treat skin tags in a natural way. Because of its acid, it can break down the cells that are excessive. Just simply, you can soak a cotton ball in apple cider vinegar and apply it to the affected areas. YOu should practise this treatment for one month or until your skin condition gets better. How To Get Rid Of Skin Tags Authority Remedies
May 08, 2014 | Computers & Internet
Printer doen't work
Need more info whats wrong??Leave more info in comments or call 225-290-5733 Thanks
May 02, 2014 | Office Equipment & Supplies
I lost my bassword sow help mei lost my bassword sow help mei lost my bassword sow help mei lost my bassword sow help mei lost my bassword sow help mei lost my bassword sow help mei lost my bassword sow...
You made a mistake, you lost your password. Learn from this, whenever you create a new password write it down where you can find it when you need to.
Dec 22, 2013 | Video Game Consoles & Games
Kenmore he5t washer Changed the pressure switch.
F21 means long drain. Yes, there is something be in the hose. You need to open the filter and clean the pump, too.
Oct 19, 2013 | Kenmore Elite HE5t Washer
What does F21 mean?
The "F21" error code indicates it takes too long for water to pump out of the tub. This can be caused by using too much High Efficiency detergent or using too much of the wrong kind of detergent. This error code can also be caused by debris clogging the drain pump. Is the error continues after you clean the filter, then you will need to replace the drain pump with this new one.
Oct 20, 2012 | Kenmore Elite HE5t Washer
I am getting a code F21 it stops about 15 min through a cycle
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it. Hope this helps... Please post back if you need more information.
Daniel
Sep 15, 2011 | Kenmore Elite HE5t Washer
What does the code F21 mean on my washer
f21 is long drain error exceeding 8 mins check drain hose for clog or filter on washer at drain pump also remove hose from tub to pump check for blockage
May 13, 2011 | Kenmore Elite HE5t Washer
Washing Machines Logo
2,204 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
