Question about Celestron NexStar 5 SE (300 x 44.45mm) Telescope
The azimuth adjustment keys don't work
The azimuth adjustment keys (left and right arrows) on my grandchild's Celestron Nexstar 5SE telescope recently stopped working. The altitude adjustment still works, however. Any ideas what to check when troubleshooting before we send it back for warranty repair?
  • 3,186 Answers
Send it back along with the hand controller describing the problem. Could be several things including a bad hand controller. If there is a local astronomy shop nearby take the scope there and ask to try one of the hand controllers in the shop and test it. If it now works you just need to buy another hand controller.
Otherwise send it in for repair
Posted on Jul 05, 2009
I have connected the hand held remote control to me Celestron NexStar 80GTL and nothing happens. The remote will not power up. Don't know if the problem lies with the remote or is a more major...
Are the batteries fresh? You can also try a new hand controller cable maybe the one you have is broken which is a common problem.
Beyond that you can try to borrow another hand controller and try it. If none of these work, then you have a blown circuit inside the telescope. It will need to be returned to Celestron for repairs.
May 27, 2011 | Celestron NexStar 4 SE Telescope
The Celestron Nexstar 4SE makes a weird cracking noise when you press the left or right arrows on the controller. I tried taking it off of the tripod, and it still will not rotate left or right, even if...
Is the AZimuth clutch locked down? Then either a gear is broken inside or the worm gear inside has slipped and is not engaing. You can return these to Celestron for repair, here:
http://www.celestron.com/c3/page.php?PageID=37
Dec 26, 2010 | Celestron NexStar 4 SE Telescope
Sound like a gear inside is either broken or the worm gear is locked up. Celestron can repair this if you call them here:
Hi, Bought a used telescope with a GT mount. The polar adjustment will not go below 46 degrees without binding. The binding screw only turns 1/4 turn in each direction and appears to be binding the...
This scope does NOT need to be polar aligned --
Here is the manual:
http://www.celestron.com/c3/images/files/downloads/1228334587_nexstargt.pdf
This is an ALT AZ goto scope. Read the manual above. You use the hand controller to move the scope in Altitude and Azimuth(left-right).
You must align it on 2 stars in order for it to has successful gotos.
Aug 21, 2010 | Celestron NexStar 114GT (269 x 114mm)...
New batteries put in....It doesn't power up
Are you SURE you installed the batteries correctly? I once installed them with ONE battery reversed. !
Jiggle the cable to the hand controller, you might just have a bad cable. You can buy a new one from Celestron.
If you can get a 12 volt power pack and the proper power cable or the 110 volt power pack-- try it on direct power. If this is a new scope I would return it to the deal if these simple fixes do not work.
Apr 09, 2010 | Celestron NexStar 5 SE (300 x 44.45mm)...
Celestron Nextar 8 doesn't track
You need to contact Celestron or a Celestron dealer:
Oct 20, 2009 | Celestron NexStar 8i (600 x 203mm)...
Azimuth Drive failure on Nexstar 114
Hi Dan, before you ship it off somewhere, you may want to try and change out the hand controller with another one that someone has and see if the problem moves.
Nov 25, 2008 | Celestron NexStar 114GT (269 x 114mm)...
Celestron nexstar 11" gps scope
Be sure that the Azimuth Axis is Lock, you migth want to try and move the telescope in the Azimuth to make sure it is it is locked. Be carful not to force it. I have seen on some post where the locking part of the Azimuth somtimes breaks. and the Azimuth Axis will just spin freely Locked down or not.
May 19, 2008 | Celestron NexStar 11 GPS (660 x 279mm)...
Celestron telescope
The hinge should be to the north. An imaginary line drawn perpendicular from the center of the tilt plate should point to Polaris (the North Star).
Mar 12, 2008 | Celestron NexStar 4 SE Telescope
No azimuth motion
Contact Celestron here:
Dec 09, 2007 | Celestron NexStar 80GT (189 x 80mm)...
Celestron NexStar 5 SE (300 x 44.45mm) Telescope Logo
228 people viewed this question
Top Celestron Optics Experts
Marvin
Marvin
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
