Question about GE Washing Machines
I bought a GE front load washer last year model # WCVH6260HWW now I'm having problems with it. It keeps shutting off during a load. I push the Start/Pause button to get it going again, sometimes 3 or 4 times during the cycle. When it finally finishes, it doesn't spin out properly and my clothes are still dripping wet. I have to ring them out by hand before I can even put them in the dryer. Any suggestions as to what might be wrong?
I have the same problem, and I believe it is because the filter is full. I'm tracking down the repair process now.
PUMP FILTER CABINET, COVER & TOP PANEL 285 WH23X10029 $68.00
I've downloaded the exploded view from GE.
Posted on Jul 13, 2009
My ge front load washer model#wcvh6260hww keeps repeating the cycle
Hi you need to clean out the drain pump assembly, sometimes there is an access panel on the front right of the washer you just pull it down and unscrew it, if this model doesnt have that, then you need to take off the front kick panel at the bottom there is 3 screws and then you will see the pump on the right where you can unscrew a canisher looking lid this is the filter for the drain pump, there will be water left in it you will several big towels. clean thoroughly should fix your problem.
Sean
Mar 28, 2011 | Washing Machines
Front load GE wcvh6260hww gasket is ripped Where do i get a new one and how do i replace?
I have not replaced a gasket myself (had warranty service) but when it was complete, I made sure to tilt the washer slightly backwards so the clothes did not get into the gasket so easily. After two replacements in the first three months, we have not had to replace for more than two years. Hope this helps when you get the new one in.
Oct 16, 2010 | GE WSXH208A Front Load Washer
I have a 2 year old GE WCVH6260HWW front loading washing machine. Last night I smelled burning and there was actuall smoke in the room. I just shut it down. To me it smelled like a rubber (belt) type...
Pull the back panel off and look at he drive belt. My pully nut loosened up and caused extreme vibration (more than usual). The pulley is aluminum and it rounded out the center hole of the pulley. The belt finally came off. I replaced the pulley and belt.
Sep 05, 2010 | GE WBVH6240F Front Load Washer
GE Washer Model WCVH6260HWW, Fabric Softener Won't Dispense/Drain
I took the tray out and placed it to the side. Then I ran a common pipe cleaner through the nozzle that supplies a water spray to the tray. So far, so good.
Jan 28, 2010 | GE Energy Star WCVH6260F Front Load Washer
WCVH6260HWW GE front load washer won't start - press the On button, then press Start/Pasue button and it goes beep beep, and keeps blinking, and washer does not start; the washer pump strainer has been...
no power to control panel checked outlet with another appliance it worked drained water from pump filter still nothing door locked and nothing on control panel
Feb 23, 2009 | GE WSXH208A Front Load Washer
Makes horrible noise during spin cycle only
The bearings have most likely gone bad. This is a very common problem with the front load washer when powder soap is used.
Jan 28, 2009 | GE WBVH6240F Front Load Washer
Washing Machines Logo
342 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
