Question about Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ...
New faucet, sprayer hooked up right, no water going into hose?
Installed new pfister single handle faucet. hard not to hook up wrong you know. but no water will come out of the sprayer?? Can you help debug this?there is no water in the hose--the main body where the on off handle is, is not letting the water into the hose? water does come out the main faucet both hot and cold.
  • sudzy007 Jul 07, 2009
    Thank you for your reply. The hose is not kinked and blowing into the hose is of no avail. Water just will not come into the hose from the main body. It appears the main body is malfunctioning at the diverter. I will attemped to reassemble the main body from the handle side. Not sure what to look for but once in there it may be obvious. I assume the diverter can be put in backwards? Again thanks for confirming my conclusion.
    Problem Solver:
  • 19 Answers
Check the sprayer handle by disconnecting and blowing into it and pressing sprayer handle and/or for possible kink at main body or hose by disconnected sprayer point hose into sink and turn on water. If no water the the diverter in main body is not working properly and needs to be reassembled or replaced
Posted on Jul 07, 2009
Diconnected faucet to clean lime build up, reconnected it and no water comes out?
Posted on Sep 03, 2009
  • Salina May 17, 2013
    Could I be missing a water or something. Bath faucet is new. Just isnt controling water to turn on and off.
    I mean a washer or something?
How do I disconnect a price Pfister quick connect?
There is a tool that presses on the collet at the tend of the fitting. It look like an open ended wrench.
https://www.youtube.com/watch?v=dCbXw5bP9I8
Price Pfister Quick Connect Sprayer Hose Removal - YouTube
? 1:50
Feb 1, 2014 - Uploaded by brianmcdrummer
In a few easy steps I'll explain how to remove your sprayer hose from your diverter. ... Pfister Faucets 17,981 ...
trick to removing price pfister quick connect sprayer hose - YouTube
? 0:23
https://www.youtube.com/watch?v=vTJefezIvwg Aug 14, 2012 - Uploaded by Biren Patel
This shows you how to remove the price pfister "quick connect" hose on the end of the kitchen sprayer head ...
Pfister - How To ' Remove a Sprayer Hose Connection
www.pfisterfaucets.com/support/faqs/sprayer ... Order Parts, FAQs. FAQs. Resources. Step by step instructions on how to remove a sprayer hose connection for the Price Pfister 529 Series faucet.
Pfister - How To ' Remove a Diverter Tee Connection for the 26 Series
www.pfisterfaucets.com/support/faqs/diverter ... Information · Order Parts, FAQs. FAQs. Resources. Step by step instructions on how to remove a diverter tee connection for the Price Pfister 26 Series faucet.
Pfister - Removing quick connect HELP ' Terry Love Plumbing ...
terrylove.com > Home > Forums > Plumbing Forum, Professional & DIY Advice Dec 13, 2006 - 6 posts - ‎5 authors
Purchased a replacement sprayer (with hose) for a Pfister Contempra faucet. How the heck do you remove the old hose from the handle assy? How do disconnect price Pfister quick connect Google Search
Jan 08, 2017 | Price Pfister Plumbing
I recently installed a Pfister Cagney Single control kitchen faucet with side spray. The spray has no pressure. The water from the faucet is great. What could be the problem?
Could be trash got into hose( i.e., teflon tape, brass shavings, etc.). I suggest that you turn off water, disconnect the hose and try flushing water through the hose with no sprayer attached. If water goes through, then you have a stoppage in the sprayer. The face of the sprayer usually unscrews allowing you to check if there is trash in it.
Apr 09, 2015 | Plumbing
How to replace a price pfister kitchen faucet sprayer
The sprayer should have a threaded fitting on the end of the hose. Unscrew old one from valve, pull hose out the top, feed new hose back down into cabinet and screw in to where old hose was attached.
Sep 23, 2012 | Price Pfister Pfister T26-4ypu Rustic...
I need a replacement handle, including all the parts and hoses, on my Price Pfister Marielle kitchen faucet model # T26-4NEE
Most new kitchen faucets feature single-handle control levers and washerless designs that rarely require maintenance. Additional features include brushed metallic finishes, detachable spray nozzles, or even push-button controls.Connect the faucet to hot and cold water lines with easy-to-install flexible supply tubes made-from vinyl or braided steel. If your faucet has a separate sprayer, install the sprayer first. Pull the sprayer hose through the sink opening and attach to the faucet body before installing the faucet.
Where local codes allow, use plastic tubes for drain hookups. A wide selection of extensions and angle fittings lets you easily plumb any sink configuration. Manufacturers offer kits that contain all the fittings needed for attaching a food disposer or dishwasher to the sink drain system.
Jul 26, 2012 | Price Pfister Marielle Kitchen Rustic...
Sink sprayer hose makes noise
hello, you may have a air pocket in the line try shutting of the water supply and then sqeeze the handle and slowly turn the water supply back on with the hose handle squeezed on till the air is forced out, hope this helps
Jun 07, 2010 | Moen 87530 Touch Control Single Handle...
Installed brand new marielle kitchen faucet with matching srpay and soap... sprayer is not working. please help
If you used the teflon tape to seal the threads on the sprayer connection. Make sure the tape is has not blocked the line.
Check for any kinks in the hose and it is not pinned against something.
Turn on the cold water and hold the sprayer over the sink and activate.
If nothing happens while still holding the sprayer move from cold water to hot. If still no water there maybe something in the line preventing the sprayer from receiving water.
Highly doubt there is anything mechanically wrong but it has happened before. See if you can swap it for a new one.
Oct 06, 2009 | Price Pfister Marielle Kitchen Faucet with...
Sprayer leaking from inside handle mechanism
although it is possible that the spray head has gone bad, it is more likely that the diverter mechanism inside the kitchen faucet needs replaced. When this part is defective, it allows full pressure from the faucet to go to sprayer head even though the sprayer is not triggered. The sprayer is not designed to handle full pressure when it is not spraying.
Jun 05, 2009 | Price Pfister Marielle Kitchen Faucet with...
New Pfister Avalon Install: Spray Hose Works, Faucet doesn't
sounds like your diverter is stuck or improperly installed ,try tapping at diverter location to free up diverter the other thing to try is remove the little device on the end of spout make sure its not clogged with debri
May 04, 2009 | Price Pfister Marielle Kitchen Faucet with...
Kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
May 04, 2009 | Price Pfister J103-BC 100 Series Kitchen...
Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ... Logo
876 people viewed this question
Top Price Pfister Plumbing Experts
Marvin
Marvin
john h
Mike
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
