Question about Panasonic Car Audio & Video
I have a panasonic dp-22 head unit and it is not turning on. how do i wire it? the head unit is goin in a 1997 chevy lumina
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
My 1997 chevy lumina 3100 v6 has ramdom misfires loss of power goin up hills and hesitation win i push gas any tips?
random misfires can be attributed to low fuel pressures and faulty injectors
with out any details as to fault codes found, check the fuel pressure at the manifold ( around 65 psi)
Feb 15, 2016 | Cars & Trucks
I have a 1997 chevy lumina 3.1.the car has 146,100 miles.It has been running rough and lose of power.I changed the EGR valve no luck.I noticed when changing the spark plugs they had a white residue on...
yes there is it usually located by the thermostat housing [top radiator hose going to the engine] its called the temperature sending unit usually a 19 mm to take of has 2 wire with connector once found unplug it if the fans come on thats your problem , and if drove around for long time [ running hot] like that can warp the heads / blow your head gaskets /and intake gaskets
Sep 26, 2013 | 1997 Chevrolet Lumina
I have a 1997 chevy lumina that won't start
check your battery first, then check your ignition switch, then check your spark plugs and wires.
Jun 29, 2013 | 1997 Chevrolet Lumina
97 chevy lumina break lights
All you need is a new brake light switch which is mounted by the brake pedal
Apr 28, 2010 | 1997 Chevrolet Lumina
1997 chevy lumina Interior lights will not shut
your door pin switch is most likely bad. it is what turns it on and off.
Feb 21, 2010 | 1997 Chevrolet Lumina
How do i bypass anti theft device for 1997 chevy lumina
most chevys have a yellow wire in the harnes that goes to the steering colum that is the security and I have had to just cut the wire to eliminate it but I would check a wire diagrahm before cutting
Jan 30, 2010 | 1997 Chevrolet Lumina
Brake wiring diagram chevy lumina
why not just replace the turn signal switch must faster and safer . buy one from your local parts house then you can see its not that easy to install but you can do it with a little help
Aug 26, 2009 | 1997 Chevrolet Lumina
1997 Chevy Lumina 3.1L Security Light Problem
check your inteior light switch. for a tempory fix remove the bulb
May 14, 2009 | 1997 Chevrolet Lumina
ERROR E1-22
uve a problem with ur laser unit im affraid needs to be replaced
Jan 16, 2009 | Panasonic Workio DP-3530 Copier
Error message on copier
That is a laser unit error. If resetting the machine's power doesn't clear it up, then it means the laser unit is dead/dying. If that's the case, your only choice is to replace the laser unit.
Oct 04, 2007 | Panasonic Workio DP-150PA Copier
Car Audio & Video Logo
334 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
