Question about Jenn-Air JED8345 Electric Cooktop
Jenn-Air JED8345 one burner does not come on
Jenn-Air JED8345 (3 cartridge cooktop unit) far right front burner does not heat but back burner works okay. The light turns on when swtich is for the far right burner is turned on but element does not work. I swtiched the right and far right cartridges and the problem is not the cartridge (the far right cartridge works fine when installed in the right slot and the right cartridge front burner does not work when installed in the far right slot).
    Master:
  • 460 Answers
The switch for the burner is bad and needs to be replaced.
Posted on Jun 25, 2017
fridgetech
  • 473 Answers
SOURCE: knob not working and some burners not heating
The switch under that knob is bad.  It's called an infinite switch.  As far as the elements go, first thing to check is for proper voltage (220) to the cooktop.  Let me know what you find.
Posted on Oct 19, 2007
SOURCE: Jenn-Air Gas Cooktop Model CVGX2423
Just had this problem today on our seven or eight year old Jenn-Air cooktop. When using the front right burner all ignitors would continue to fire until I turned off the burner. The three other burners worked correctly. After trying all the obvious soulutions w/o success I pulled off that burners control knob and the rubber seal which exposed the valve. Their was a bunch of crud in there. I put a small (one inch) paint brush in there and vigorusly loosened all the crud. I then inserted the nozzle of our central vac - which just happened to fit perfectly - and sucked all the stuff out. I repeated the proceedure a couple more times, reassembled the knob and started the burner. Worked just perfectly!!! YMMV. Good luck.
Posted on Feb 08, 2008
Eddie Rentas
  • 59 Answers
SOURCE: jenn air jed 8430 electric cooktop control switch for rear burner
The cook top is attached to the wood frame by brackets, just remove the screws and the electric connection, make sure the power is off from the main box, it's a 220 volt wiring and then just lift the top off. to remove the glass, look around the edges and you should see some small screws, just remove them and the glass should lift off.
Eddie Rentas
Tupper Lake NY
Posted on Jul 23, 2008
mgprice
  • 744 Answers
SOURCE: Gas Jenn Air Cooktop Issue with Electric Starter
Did you spill water near/on knobs? if so leave to dry out for 24 hours. If still clicking after 24 hours one of the switches has shorted out and needs to be replaced. You can find which one with a multi meter/condinuity test. Hope this helps...Good Luck
Posted on Jun 26, 2009
  • 13433 Answers
SOURCE: Jenn-Aire ccg2523 Natural Gas sealed cooktop.
parts for your cooktop are available at
http://www.partselect.com/MultiModels.aspx?ModelNum=ccg2523&searchTerm=&RefineSearch=0
have a look at the part diagrams, they may help you on taking it apart.
Posted on Jul 02, 2009
Right front burner fails to heat (at all) Jenn air
I suspect a faulty element or electrical connection to the element.
Mar 21, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
2 right burners on my Jenn-Air JEC9536 cooktop stopped working.
I have a JEC9536ADB electric Jenn-Air Cooktop. We replaced the class top and now the knobs are all spliting and won't work. 2 of the main burners will only heat in the "high" position? What do I need to replace?
Sep 25, 2009 | Jenn-Air 35 in. JEC9536 Electric Cooktop
I have a jenn-air sealed gas cooktop jcg8430 only 1 burner lights
you have a problem with the ht leads or spark electrodes
Aug 18, 2009 | Jenn-Air Cooktops
My jenn-air JEC9530 is red light blinking.
you will need a new heating element in and if that dosent work you need a new one
May 30, 2009 | Jenn-Air JEC9530 Electric Cooktop
Jen Air left front small burner does not heat up.
these are cartridge elements corrrect? try reversing the cartidges, now the front small will become the rear small . does it not work in this position? and the newly placed front burner work?? this will determine if the proble lies within the cartridge or the switches
Feb 22, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air JGD8130 Gas Cooktop
grab hold of the installed burner cartridge at he top of unit and pry up slightly, should lift up without much effort, if not try lifting front side. they jsut lift up and slide back in no screws hold them in place
Feb 21, 2008 | Jenn-Air JGD8130 Gas Cooktop
Jenn-Air JGD8130
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
Knob not working and some burners not heating
Oct 19, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8345 Electric Cooktop Logo
304 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
