Shontek clock movement from Sam's club not keeping time
Hi - I have a similar problem - I removed the screw and plastic snap on movement cover and gently blew dust and debris from the gears, which then seemed to work fine. the clock still won't keep accurate time (or anything near accurate time - so much for atomic accuracy!)
i plan to buy a new movement from klockit.com for about $20 - i first need to remove this movement and measure the hands, etc. so i order the right parts.
Were you able to repair your clock ? I have the same 24" clock from Sam's Club and have given up on finding the Shontek DM2720 movement. Please let me know.
Posted on Aug 03, 2010
Can we buy a shontek dmp-201 movement from you? we have a danbury clock with a movement that doesn't work.
sadly this isnt a place for buying or selling however it may seem as if the clock work parts could be found online or by replaceing/retro fitting a differental type of clock work
Feb 23, 2017 | Home
How much should the clutch adjustor screw move within the basket when you remove the clutch cable
Hi Sherry, The clutch adjuster screw is held in place by a bearing and the bearing is held in place by a c-clip or snap ring can't remember anyways there should be zero movement only rotation. These are parts that in my 35 years of wrenching I have never seen fail, but there is always a first time for everything. That being said its more likely that 1 or 2 of the 3 ball bearings that are located between the inner and outer ramp of the clutch release mechanism has fallen out. It can happen easily if you are not carefull when you have the primary cover off. Normally the mechanism is held in place on the inside of the primary cover with a c-clip or snap ring. Once it's removed thats when you can loose a ball or two. I would drain the primary, inspect the drain plug magnet for large metal chunks, pull the primary cover and look for missing ramp balls and or c-clips and snap rings. grab the clutch pack and see if has abnormal movement either in and out or up and down. Clutch hub nut could have loosened but highly unlikely. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 16, 2015 | Harley Davidson XLH Sportster 883 Hugger...
How do get the face of my dash off a 2001 honda accord to remove my stereo
To remove the center dash panel to access your radio follow these simple steps -
  1. First there are three Phillips screws that secure this dash panel to the main dash assembly.One of the screws is hidden behind the clock.
  2. The clock unsnaps from the dash panel, but requires a very small flat head screwdriver or similar flat tool. You need to Insert the tool into the side gap between the edge of the clock assembly and the dash panel. Gently pry out that edge of the clock. Insert your fingers into the gap and pull firmly to completely remove the clock from the dash panel.
  3. Now you need to locate and remove that (hidden) Phillips screw.
  4. Now look on the curved underside of the dash panel. Locate and remove those two Phillips screws.
  5. All screws securing the dash have now been removed. The plastic dash panel itself snaps into the main dash assembly. Begin by pulling gently on either the bottom curve of the dash panel or one of the top corners of the dash panel. Continue to pull until all sides of the plastic dash panel have slightly pulled away from the main dash assembly. Now pull the entire plastic dash panel away from the main dash assembly.
  6. Now turn the panel around exposing the wires attached to the back side. Unplug all connectors attached to the air conditioner controls. The radio is secured by four screws, your vehicle will either have four Phillips screws or four 8 mm bolt screws. Remove the screws//bolts and pull the radio out of the dash. Unplug the wire harness connector and the black antenna cable from the rear of the radio.
  7. The center dash is now removed and you now have full access to your radio.
Regards, Tony
Apr 18, 2011 | Audio Players & Recorders
How to remove tail lite cover on 2002 xteara
Open the back gate and you will see a couple of philips head screws. Unscrew them and snap the tail light out gently. There a couple of plastic clips that hold the tail light in place. Be careful not to break them (pull the light straight out not up, down, left, or right) Once the tail light cover is removed, separate it from the backing and reflective insert.To change the bulbs just twist counter clock wise and push in. Snap the new bulbs in and repeat the whole process in reverse.
Nov 15, 2010 | 2002 Nissan Xterra
Replacing timer motor
T-104 has 240Volt clock motor
WH-40 water heater timer has same 240Volt clock motor
T-103 has 120Volt clock motor
T-101 has 120Volt clock motor
T-100 series 120Volt and 240Volt clock motors sell at Grainger for $16
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
See large image of clock motor on back of Intermatic timer
http://waterheatertimer.org/images/Back-of-T-104-800.jpg
To replace clock motor you need 6-sided star-screwdriver from auto parts store or hardware
You may also need tweezers or magnetic screwdriver if tiny screws fall down behind timer when replacing
Steps:
Order 120 or 240 volt clock motor
Turn off power to timer
Remove plastic cover over screw terminals
Take photo of wiring or make a drawing
Note exactly which terminals the clock wires connect to
Clock motor wires can connect to either terminal, there is not a plus or minus wire to clock
Loosen screws on front of timer to remove white-colored clock motor wires
Push the spring retainer located inside box at top ... this will release timer mechanism from box
Tip timer out and then lift up to release timer
Replace clock motor that is held by 2 screws
Keep clock wires away from other timer parts on back of timer
Snap timer back into box
Re-attach wires to terminals just like they were before
Tighten screws very tight against copper wires
Turn on power
Check that dial is rotating as time passes
See more
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Oct 17, 2010 | Intermatic T-104R3 220v timer in a rain...
How do i change the bulb
Please follow the steps to change the bulb.
1.Turn the television off and unplug the AC cord.
2.Remove the front speaker grill by gently pulling on each side. The grill will snap out.
1bb40b3.jpg 3.Using a Phillips screwdriver,remove the three screws that hold the recessed plastic cover in place.
4.Remove the plastic cover and set aside with the screws.
5.After removing the cover,you will be able to see the lamp cartridge.With the screwdriver,loosen the three screws of the cartridge. The three screws will not completely remove.
6.Gently grasp the metal handle and pull straightout (towardsyou).
7.Insert the new lamp cartridge securely into theTV.Donot touch the glass surface of the cartridge.
8.With the screwdriver,tighten the screws on the lamp cartridge.
9.Replace the plastic cover and screws.
10.Snap the speaker grill back into place by pushing It into place on each side with the palm of your hand.
thanx
Aug 01, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Radio controlled clock not working
Pretty simple: Press reset. Clock should reset within 10 minutes.
Manually set by pressing Set and holding for 5 seconds. The hands will turn. Release when they get to the correct time.
Mine quit working after a year and seems to be dead. The movement won't do anything now with a new battery.
May 10, 2009 | Audio Players & Recorders
Remove door panel on a Ford Van
For a 1999 Ford Econoline 150 (assume the same or very similar), remove triangular plastic cover over mirror assembly by prying straight out, remove plastic door handle cover by prying up from the front side, remove electronic door switches by prying up from back side, remove round plastic cover at bottom rear of door panel. Four screws are now revealed, remove them. Lift door panel straight up, clips are hooks (not snap in). Work door switch assembly out of door panel. Set door panel aside. Reassemble in reverse order.
May 09, 2009 | 2000 Ford Econoline
Need instructions to replace the bezel on a gateway 7330gz
Just like any other laptop LCD screen, edtechservic. Remove the rubber caps that cover the Philips head screws, remove the screws, and work around the bezel to pop it loose, a little at a time.
Top cover up, you are looking at the LCD screen. Look at the top Left and Right corners of the screen bezel. Look in-between. Now look along the bottom of the screen bezel. See those small rubber caps? G-E-N-T-L-Y pry them loose with a 60 or 90 degree pick. (In your computer repair kit)
Use care, and finesse! You don't want to scratch the clients laptop!
Now loosen, and remove the screws underneath.
Use a Jewelers flat tip screwdriver, (No.2), and ease it in the parting line, that you will see between the bezel, and top cover. Don't go more than a 1/4 inch in! You could be up against the LCD screen metal frame, if you go too far in. (Which could break the LCD screen)
Won't ease in there? Move over an inch or so. You could be hitting the plastic part of the bezel, that snaps down into the Top Cover.
There are several of these plastic protrusions, that stick down from the bezel, and snap into place in the Top Cover. Every few inches or so.
After you start easing one of these plastic snaps out, (Plastic protrusion I spoke of above), move along the edge, pick another place, and start easing it up. Keep bringing the edge up a little at a time. (Bring the back of the flat tip jewelers screwdriver down)
When you have gone along, and raised a large portion of the bezel, you should hear a distinct Click, as one of the plastic snaps come out of the Top Cover.
If not, move back to the first plastic snap that started to come out, and place your flat tip Jewelers screwdriver next to it. Bring the back of the screwdriver down to pop that plastic snap up, and out.
Hearing it your first time might make you a little stomach sick. You'll think you broke something! If you go along, and raise the bezel up a little at a time, you'll be okay. The bezel is made of space age plastic, and is VERY tough! You can't get crazy with it though!
When you have gone almost all the way around the bezel, the last few inches may just pop up, and out.
This link shows you with photos, and information, for a Gateway MT6704 Notebook PC,
http://www.insidemylaptop.com/remove-lcd-screen-from-gateway-mt6704-model-ma7/
This guide is to completely replace the LCD screen. You can just use the information under the first five photos, for bezel replacement.
Nov 15, 2008 | Acer Aspire 3000 Notebook
Cover
there are two screws at the bottom... u need a t6 and a t4 screw driver set to take off your cover..you need to lift the plastic just above the inner screen and remove two more screws there..the face should just pop right off with a little prying...
sam !
May 10, 2008 | Motorola Mobility PEBL U6 Cellular Phone
2,799 people viewed this question
 Grubhead
Grubhead
