Question about Tascam CD-RW2000 Burner
Tascam CD-RW2000 CD tray sticks- I have to push the open/close button repeatedly unitl the tray finally opens and then it does not immediately recognize the CD.
Whenever I turn my burner on, it just sits with the welcome sign on the screen. The drawer does not open but it sounds like it would, but it does not move. What could be wrong or what do I need to fix it
Tascam cd rw 700
Posted on Feb 17, 2010
  • 2,427 Answers
THE CARRIAGE UNIT (CD TRAY) is damaged, replace the tray
or the drive
or u can use it as is until its dead
Posted on Dec 30, 2007
How can i open my cd drive to insert my cd?
If the button on the drive won't pop open the drive, then you need to find out what is causing it to stick closed. Most drives have a tiny hole on the door so you can push a paper clip in it to open the door.
Jun 17, 2015 | Computers & Internet
My tascam cc-222 read welcom want open
Is there a CD stuck in the unit? Did you push the tray to close? If non of the above you must remove and open the top to see what happened
Jul 08, 2011 | Tascam CC-222mkIII CD Player / Recorder
I have a TASCAM CD-450 that the CD Tray will stick closed on quite frequently. I can open the cover (out of warranty) and manually press down on the lens mounting tray and it will open with power. The...
I have the same Tascam cd-450 with the same problem. I replaced the tray motors drive belt and it didn't fix the issue. I measured the voltage output to the motor after pushing the eject button and it was about 1.7 vdc with the tray motor plugged into the main board and about 2.5 vdc with the tray motor unplugged from the main board. I'm beginning to think that the rf-500tb-14415 motor is weak but I don't know the original main board output voltage spec for this motor. I do know that this motor is rated from 1.5 vdc to 9 vdc (3 vdc or 6 vdc nominal)depending on the application and torque requirement.
Sep 27, 2010 | Tascam CD-450 CD Player
I cant open my cd tray on my tascam dp01
Look on the front of the CD tray for a little hole... push the end of a paper clip in the hole and the tray should open.
Dec 12, 2009 | Tascam DP01 All-In-One Recording Package...
Actually, I have a CD-RW700 Burner and the door won't open. Burner works great though. Any ideas?
just change/replace the 'cd loader belt'..
clean n grease all the gear assemblies..
if u r not a professional, try contacting ur system admin/vendor....
Nov 12, 2009 | Tascam CD-RW2000 Burner
Whenever I turn my burner on, it just sits with the welcome sign on the screen. The drawer does not open but it sounds like it would, but it does not move. What could be wrong or what do I need to fix it?
It seems to be if you look at the front, where you can see the button, you will find a tiny take a paper pin and insert it in the hole and the tray should come out...then you can clean it.
Sep 10, 2009 | Tascam CD-RW2000 Burner
Tray won't stay open
My unit closed immediately upon opening since like 1 day after the warranty ran out. It bothered me. I finally tore it apart and this fixed it.
Take the cover off. As you are facing the front of the player, the blue sensor switch that controls the tray will be on your left in the middle of the carousel. Push button to open tray and locate it as the tray opens. Grab the tray and also the carousel and hold them so you can see the little blue switch. Use a tiny screwdriver or toothpick or other slender device to "flick" the switch fully forward and backward several times. Let go of the tray and try the button. If it still closes immediately, repeat the flicking. Try it again.
Jul 09, 2009 | Pioneer XV-HTD520 Multi-disc DVD Player
Tray will not eject on LTR 16102B CD-RW
Most likely due to a worn belt. You can use a paper clip in the manual eject hole while pressing the button repeatedly to get it open. The belt or the drive will need to be replaced.
Jul 07, 2008 | Lite On LTR 16102B CD-RW Burner
CD player problem
Seems like the Timingfor the Tray Open / close has got disturebed. Could be a bad drive gear, or as simple as a loose Drive belt. Get it checked by a professional.
Sep 19, 2006 | Sony MHC-RX70 Shelf System
Tascam CD-RW2000 Burner Logo
519 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Chris Larocque
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
