Question about Northstar Professional Series Pressure Washer 4000 PSI
Burner won't ignite
I have a Northstar St40004nm
4000 PSI 4 GPM 21oF
The pressure washer works but the burner will not ignite, and yes I do turn the switch to on.
  • 226 Answers
SOURCE: Foaming in pump oil window
I dont know which comet pump you have, but it is just easier to get a new pump from one of the pressure washer companies on the internet and they sell them on ebay. You can also probably get a better pump that will fit your engine as well. Also, have you tried just changing the oil and not fill it too full? On my 5000 lb washer, if i fill the oil too high when I change the oil, it will foam some. Hope this helps you, Rick
Posted on May 04, 2009
  • 174 Answers
SOURCE: northstar pressure washer randomly gives pressure
Hi:
You need to find the bypass (unloader) valve and grease it with a good waterproof grease. Sorry, I cannot find a pic for you
Posted on Sep 03, 2009
  • 56 Answers
SOURCE: my electric stea pressure washer wont ignite
There can be multiple problems with the burner.
Here is a link to a page for troubleshooting burners.
link
Posted on Dec 21, 2009
  • 608 Answers
SOURCE: Northstar PW shuts off hot if washer is moved. Honda engine
Being petrol driven, it may have a mercury kill switch which puts a ground on the ignition circuit stopping the engine if you move it. Perhaps for safety in case you overturn the unit somehow.
Posted on Apr 08, 2010
  • 50 Answers
SOURCE: I have a northern 3000
if it gettin diseal to nozel it ur photocel r thermostat
Posted on Aug 03, 2010
Burner lights for a few seconds then goes out and wont relight mod # 1572251a
this could be a number of problems, first thing is replace the fuel filter
Dec 30, 2010 | Northstar Gas Powered Wet Steam & Hot...
Burner runs but will fire when trigger is pulled
the burner should fire (kick in) when the trigger is pulled,and switch off when you release the trigger.
Dec 28, 2010 | Northstar Gas Powered Wet Steam & Hot...
Engine runs fine, pump works, but it's not kicking the burner on ?
The first thing I would check is spark on the electrodes in the burner, if you pull the transformer down from the bottom of the burner you will see two springs that touch metal poles in the bottom. You are going to have to have someone else run the machine in cold water mode (these machines will create spark in cold or hot water mode) and holding onto a long insulated screwdriver you are going to get about 1/4 inch away from each of the springs and see if a spark comes across the spring and the screw driver. Be very careful in doing this, you are playing with a lot of power. If no spark then this would indicate that you have a fuse blown or the transformer is bad. You would then proceed in checking power to the transformer. If you are getting spark then it is going to be one of the safety systems that is giving you a problem. Let me know what you find out.
Oct 27, 2010 | Northstar Wet Steam & Hot Water Pressure...
I recently purchased a northstar 4000 psi pressure washer. I had the same series pressure washer for the past 6 years and used a downstream chemical unloader quick connect to pull chemical. I attached it...
The injector might be worn out or have something inside of the valve causing it not to ****. If you are using a new high pressure hose or a longer hose this may also have an effect over the injector not working.
Oct 06, 2010 | Northstar Professional Series Pressure...
I have a northstar pressure washer 2000pw serial #03005610 item #157754b someone has took carb off and u was wonderin if u could give me a blowup of how the linkages and springs go ?
You will find your information by looking for model number and code of engine. Look on the fan cover, valve cover engine block or tag directly on the engine itself. Example would be Honda model gx340 from starter of engine. Then check google or mfg. web site for manual showing governor linkage. Norhstar uses several brands of engines. Good luck
Sep 08, 2010 | Northstar Pressure Washer Trigger Spray...
Won't heat
sound like its not getting a spark at your electrodes.
Apr 07, 2010 | Northstar Electric Wet Steam & Hot Water...
Smokes bad when burner kicks on
Hey mate,
What brand of burner are you running? I am a Karcher Tech but they all work on the same principle,
Your burner is getting to much diesel/kero, most have little flow swicthes on them to tell them to pump fuel or spark when there is water present in the burner coil, if this switch is faulty or getting a faulse reading then it will tell the unit to pump fuel when it is not needed and this will cause very excessive smoke for the first few mins when the burner kicks in...
If you have the excessive smoke continuously(even after 10 mins of continous use then it is probable that your fuel pump/system is running to rich, these units need regular servicing and adjustments as fuel nozzles/components wear,
There is alot of precise adjustments and checks on these units and i would reccommend getting it checked by a qualified tech, as when there is heated fuel and spark these units can be dangerous!
Hope this helps
Regards
Brad
Feb 03, 2010 | Northstar Electric Wet Steam & Hot Water...
My electric stea pressure washer wont ignite burner
link
Dec 21, 2009 | Northstar Electric Wet Steam & Hot Water...
My Northstar Turbo nozzle emits a solid stream of water without any turbo action.
NorthStar Pressure Washer Turbo Nozzle --> --> Turbo nozzle sprays up to 3.1 GPM at 2300 PSI and 194°F. Unique design delivers 0° high pressure impact with wide angle spray coverage.
The point of the Turbo is that it is a solid ( high pressure stream of water )
Oct 19, 2009 | Northstar Pressure Washer Turbo Nozzle
Northstar Professional Series Pressure Washer 4000 PSI Logo
124 people viewed this question
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
