Question about Uniden Cordless Phone
I have a new GE phone Thompson Model 27906GE1-A, Serial # 80248625. Displays "no battery", although battery is plugged in and charged. Unable to use phone. Can this be fixed with reset or other method?
The "new Message" light will not go off. All
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Nov 30, 2010 | GE RCA G.E. Thompson 25414RE3 4 line...
ID fading unable to see number or letters, can this problem be solved?
Try putting new batteries in the handset. Many phones will dim their displays when the batteries start to run low in order to save power.
Hope that helps!
Jul 10, 2010 | GE 25952EE1 Cordless Phone
The corless base doesnt charge the phone
This particular model of GE Phone + 1 cordless phone is garbage. Its a problem I have seen many times where the cordless set isnt being charged by the base like it should.
Actually, what the problem is, your handset more then likely has a loose or broken wire inside it that connects to the battery and the charging nodes. and is probably not able to be fixed.
Although you can buy a new extra handset from most websites that sell that model of phone, or even a electronics store if they have it.
Mar 09, 2010 | GE 26958GE1 Cordless Phone
Unable to charge battery
Clean charging port, remove battery, clean contacts between battery and phone, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.
Oct 19, 2009 | Motorola Mobility RAZR V3
I have bought a GE cordless phone model 29670, base unit working fine but cordless unit no sound or display even though battery charged more than 10hrs before first use.
I took the phone to the shop where I purchased, they replaced the battery cordless unit with a new one, now it is OK. All displays are perfect.
Thanks & regards
Balakrishnan.
Oct 13, 2009 | Uniden Cordless Phone
BATTERY UNABLE TO CHARGE, ALTHOUGH PHONE WORKS
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone.
Razr V3 external battery charger
May 27, 2009 | LG VX9400 Cellular Phone
Answering switched to handsets
is the phone totally/fully charged
Nov 26, 2008 | Lands Phones
Main base not charging
no you need a new battery. Hope this helped you
Nov 18, 2007 | GE Thompson 25901EE1 Cordless Phone
Uniden Cordless Phone Logo
341 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
