Question about Faberware FCP240 Coffee Maker
138 - Faberware FCP240 Coffee Maker
    President:
  • 1,952 Answers
What is ur problem?
Posted on Jul 01, 2009
Looking for a Kenwood KDC X397 owner’s manual? .
Yes of course. See the link
hard copy of this Google Search
KDC-MP238/CR KDC-MP208 KDC-138/CR - Kenwood
manual.kenwood.com/files/B64-3898-00_00_KW.pdf
Translate this page
2 ' KDC-MP238/CR/KDC-MP208/KDC-138/CR. Contents. Before use. 3. Basic Operation. 4. General functions. Tuner functions. Disc play functions. General ... Menu Operation. 10. Menu System. Activating Security Code. Deactivating Security Code. Manual Clock Adjustment. Auxiliary Input Display Setting. Receive mode ...
Kenwood KDC-138 CD Player User Manual - ManualsOnline.com
www.manualsonline.com > ... > Home Audio Kenwood > Kenwood CD Player Record the serial number, found on the back of the unit, in the spaces designated on the. warranty card, and in the space provided below. Refer to the model and serial numbers. whenever you call upon your Kenwood dealer for information or service on the product. Model KDC-MP238/CR/MP208/138/CR Serial number.
KENWOOD KDC-138 INSTRUCTION MANUAL Pdf Download.
https://www.manualslib.com > Brands > Kenwood Manuals > Car Receiver > KDC-138 View and Download Kenwood KDC-138 instruction manual online. Kenwood CD-RECEIVER INSTRUCTION MANUAL. KDC-138 Car Receiver pdf manual download. KDC-MP238/CR KDC-MP208 KDC-138/CR CD-RECEIVER INSTRUCTION MANUAL AMPLI-TUNER LECTEUR DE CD MODE D'EMPLOI REPRODUCTOR ...
Connecting Wires To Terminals - Kenwood KDC-138 Instruction ...
https://www.manualslib.com > ... > Car Receiver > KDC-138 > Instruction manual
Kenwood KDC-138 Manual Online: Connecting Wires To Terminals. To Kenwood disc changer/ External optional accessory (KDC-MP238 only) Fuse (10A) Wiring harness (Accessory1) Power control/Motor antenna control wire (Blue/White) TEL mute wire (Brown) Not Used (Blue) White/Black White...
Kenwood Car Stereo Head Unit Replacement Wiring Harness Plug ...
https://www.amazon.ca/Kenwood-Stereo...Wiring-Harness/dp/B005X273W8 Rating: 4.7 - ‎15 reviews
Kenwood Replacement Stereo 16 Pin Wire harness; Top quality all copper 18 gauge leads. Perfect Fit.Molex type 6 inch long black color; KDC KRC DPX KTS models see the descrition for model compatibility; Kenwood power harness plug 16 pin indash radio and video units; Allows for installation of an aftermarket radio ...
Mar 23, 2018 | The Computers & Internet
Can you send us a picture of the kawasaki zx750 carb
Now that that\'s out, this page is all about jetting a motorcycle. I will only apply one set of jets and make one series of adjustments. The motorcycle that this paper demonstrates is a California model 2002 Kawasaki zx-7r. The "Jet Kit" applied is by Factory Pro. For the series of pages I will cover California emissions removal, Adjusting the carburetor float height and a modifcation known as "The float bowl mod" as gleaned from the vast resource known as the zx7r Owners Club Discussion Forum, Perhaps the greatest motorcycle resource known to man.
Step 1 - Preparation
Airbox
Remove the gas tank and air filter until you are looking at the bottom of the airbox.(Upper Right) Clean out the inside of the airbox while you are in here, there\'s no time like the present. Disconnect the the PCV hose from the bottom of the airbox. (Upper Left)Turn out the three screws and remove the airbox (Lower Right).
Put all the screws in a box and get them out of the way! You won\'t be seeing them for a few hours so the further the better. (Lower Left)
Step 2 : Smog
Smog
Removing the California Emissions from your streetbike is *******. For race applications tho, it\'s all good. The California emissions is a bit more complicated than the 49 states setup(upper left), but you might notice that they have only added an evap system to it (Upper Right). Other than that I can\'t tell a difference. What we will be removing is everything emmisions, short the PCV hose that is mentioned above. When everything has been removed join the two reed plate hoses at the top. You can also buy a block off plate from Muzzy\'s or some other race manufacturer. When you have removed all the smog, you should have a box of junk similar to the one on the right, because I intend to put the smog back on, I will be keeping all the gear.
]Finally, plug off the four vacuum lines that go into the head benieth the carbs: Use 5/32" plugs.
Ken Waters\' Patented "Float Bowl Mod"
This modification is the brainchild of Mr. Ken Waters, who was clearly a brilliant technician who has passed away in an unfortunate accident. I don\'t know much about his passing. Speculation is that the accident was not motorcycle related. Reading thru Ken\'s posts on the Zx7r Owner\'s Club Discussion Forum has helped many motorcycle owners, and myself, understand a load more about how bike tuning is done.
Principle: (As paraphrased from Ken Waters)
In order to get the pressure in the float bowls equal to the pressure in the airbox, racebikes enclose the entire carb assembly in the airbox. As logic, fate would have it we are supplied with little hoses that run into the float bowls of our carbeurators. We are going to exploit these hoses to ballance the preasure throughout the fuel system.
Situational Information:
Now, as if knowing the two hoses that appear to come from the top of the carbs and indeed are attached to the top of the carbs are the ones we are going to use isn\'t confusing enough, I\'m going to tell you that they are connected directly to the float bowls which are at the bottom of the carb assembly. When we pull the carbs off later you will see that the tap is at the top, and the orifice is in the float bowl.
Application:
It\'s real easy. Just connect the two hoses that are discussed above directly to the airbox. There are many opinions about how to do this, I chose to destroy as few parts as possible in an effort to keep as many of the stock parts in tact as possible. I melted one end of a leftover vacuum "T" shut (Upper Right) and connected it to the hose that used to connect the evap cannister and intake silencer to the airbox(Upper Left). Again, trying to keep as many stock pieces stock, I plugged off the other line to the airbox with a screw(Lower Right). I do however, suggest using this other line to connect there, as it can provide a better seal to the airbox. I compensate for this by using a hoseclamp on the one I used.
Note: No matter how you connect it, connect the line where the clean air is, between the air filter and the carbs.
Step 4: Install and Adjust
Finally We Work The Carbs!Disconnect the fuel line where it t\'s off into the carbs.(1) Open the throttle assembly on the handle bars and let the slack out of the throttle cable there. (2) Pull the two throttle cables off the carbs and lift the throttle cables from their pirches. Loosen the four mainfold clamps and remove the carbs by pulling out and up at the same time. (3)
Once they\'re out, turn the carbs upside down on the work bench and remove the sixteen screws that hold the float bowls on (4) and remove the float bowls. Place carb assembly on its side to remove any pressure from the floats and measure the float height with the floats resting lightly on the float pin so as not to push it in at all, but not rise above it either.(5) The floats stock should mesure 13mm. We need to change this to 15.5mm for our Jet Kit. Do so by bending the little tab between the floats and the float pin. (Right)
After you\'ve adjusted the float hieght, remove the main jets and emulsifier tubes and replace them with your choice of factory mains and tubes. I chose the 168 outer / 178 inner (Smaller) combonation because of my altitude.(6)
Remove the four black caps on the top of the carbs. (7) Be careful because they are spring loaded! Remove the needle jets and place shims "as necessary" (Consult with Factory Pro or a tuner in your area about this.) My favorite wrench jockey suggested two shims and so far it seems he was right, response is genuinly smooth all the way through. Replace the stock springs with Factory springs if provided.
To finish of the mods, I added a 4 degree Factory ignition advancer.(8) An easy install that smoothes out throttle response even further.
Oct 21, 2014 | Motorcycles
Pfaff instructions
here are 2 links, choose which one you want to buy from
Pfaff 138 138 6 Instruction Manual
Pfaff 138 Parts
Jul 11, 2014 | Sewing Machines
1999 flhr road king shock air pressure
Recommended Suspension Air Pressure: FLHX, FLTRX, FLHR/C
SHOCK LOAD TOTAL WEIGHT PRESSURE
LB. KGPSI kPa
Solo rider up to 150 up to 680 0
150-200 68-91 0-10 0-69
200-250 91-113 10-20 69-138
250-300 113-136 20-30 138-206
over 300over 136 30-50 206-345
Solo rider with capacity
luggage of 40 lbs (18 kg) up to 150 up to 68 10-20 69-138
150-200 68-91 20-30 138-206
200-250 91-113 30-40 206-276
250-300 113-136 40-50 276-345
over 300 over 136 50 345
Rider plus passenger ALL ALL 40-50 276-345
Maximum GVWR ALL ALL 50 345
If Tour-Pak is installed, add 5-10 psi (34-69 kPa) to shock pressure.
Do not exceed 50 psi (345 kPa) suspension pressure.
May 13, 2014 | Harley Davidson FLHR Road king Motorcycles
Subwoofer option on my kenwood kdc 138 receiver
go to kenwood wesite to down load instruction manuals
Sep 13, 2009 | Kenwood KDC-138 FM / AM Receiver
CODE 138
Hi..my name is Keith..and im assuming you have OBD II..and the code 138 means that...O2 sensor circuit,high voltage(cyclinder bank #1,sensor #2)..i hope this will help you
Nov 21, 2008 | 1996 Dodge Dakota
Faberware FCP240 Coffee Maker Logo
52 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Starnley Johnwells
Starnley Johnwells
Steve
Kolbrun...
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
