Question about Sony STR-DE1075 Receiver
PROTECT the display in ma receiver says PROTECT all the time. I think this happened after one of the speakers fell down on the floor. should I buy new receiver or speakers, or maybe there is something i can do to fix the problem. thank you.
  • MHJiE Nov 09, 2007
    I think my husband tryed that already and it didn't work. is there anything else I can do?
    Problem Solver:
  • 12 Answers
Try disconnecting the Speaker that fell, and then turn the unit on. If the protect signal goes away, There is probably a problem with the speaker and it will have to be repaired/replaced.
Posted on Nov 09, 2007
I have Kenwood kdc- mp343 it displays protect then what happens?
Disconnect all speakers from unit. Turn on. If still in protect then unit is damaged and needs repair. If not then reconnect 1 speaker at a time until it goes into protect. That speaker is either shorted or wiring is shorted.
Oct 30, 2016 | Kenwood Car Audio & Video
When on the stand by button on display come and display showing protect how do i rectify the protect mode?circuit diagram?
protect mode comes on generally when speaker have shorted. disconnect the speakers & try. If it powers on properly try one speaker at a time till you find out which speaker is causing the problem
Dec 23, 2010 | Denon AVR-2800 Receiver
No sound , display shows digital protect
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Jun 09, 2010 | Sony STR-DE685 Receiver
My kenwood KDC-X693 displays protect,any solution?thanks
i have dat stereo in ma 97 chevy s10 and the two front speakers were da problem i had to chenge them so i did den like a week later in went bak into protection mode so i ended up running new wires and its been working fine its been like 3 months so when it says protect its in protection mode either you have speakers with reversed polarity or its what happen to mine run new wires
Dec 23, 2009 | Car Audio & Video
PROTECT DISPLAYED ON RECEIVER
This generally means you've got a short somewhere, and the received is trying to protect itself.
My suggestion is to disconnect all of your speakers at both ends, and reconnect them.
Most times this happens because a speaker wire is lose, and the positive and negative connections are touching each other, causing it to short out.
Mar 24, 2009 | Sony STR-DE485 Receiver
Getting a "Protect" message in the display which then shuts down
The speaker wires were al little frayed, so I cut and stripped new 3/8" leads and when re-inserted the receiver worked fine. The problem was a short from the frayed wires touching either the back of the receiver or some other metal near the terminal.
Dec 06, 2008 | Sony STR-DE185 Receiver
Display
you want to put new software to your mobile. And service your mobile in mobile shop. why mean i think mobile is fell down i think!
Jun 30, 2008 | Nokia 6288 Cellular Phone
Ma lap top fell down
sorry ok. what i will suggest iis yu replace your screen and zap yr done.
thank u
May 25, 2008 | HP Compaq Presario V2000 Notebook
Reciever turning off.
You have a short in the speaker wiring. Simply put, the pos and neg (red/black ends) of your speaker wire are most likely touching somewhere. The receiver has a short protection circuit that keeps you from blowing the receiver or your speakers. Either try re-cutting the ends of the speaker wire, or if that doesn't remedy the issue, buy new speaker wire.
Jun 18, 2007 | Onkyo TX-SR601 Receiver
Protection mode keeps kicking in
This happens less often in "normal surround" mode
Apr 01, 2007 | Sony STR-DE485 Receiver
Open Questions:
Sony STR-DE1075 Receiver Logo
150 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
