Question about Nikon Speedlight SB-800 TTL Flash
Cannot set shutter speed above 250
I know it can be done but I dont seem to be able to access all the fuctions on the SB-900.
I have a D3x.
You have to enter the menu by pressing the "OK" button until the menu appears. By scrolling all the way down you will find a setting where you can choose "FULL menu". You can also choose to set up an individual menu.
To set shutter speed above 250 you have to ensure "FP" for high-speed sync is enabled on the flash.
//Peter
Posted on Jul 08, 2009
I'm having a couple problems with my Nikon D90 and for the life of me that manual is too confusing, The first problem I'm having is.... I'm taking pictures at my sons wrestling events and I can't get it...
I imagine your son's wrestling events are held in school gyms with lighting that is less than ideal. If you are taking pictures without a flash then the blurriness you describe could well be due to a slow shutter speed. Your camera is using a slower shutter speed to gather enough light, but your subjects are moving fast enough to cause motion blur in the picture. Either you increase the aperture (larger aperture = smaller f number), increase the ISO number (equivalent to film speed), or you use a flash. If you do use a flash, the built-in pop-up flash is only useful for close shots probably no more than 15 feet away or so. A speedlight flash, such as the Nikon SB-400, Sb-600, SB-700 or SB-900 will project the light much farther.
If you set your ISO manually to 1250 or 1600 and put your D90 on shutter-priority (the "S" on the left dial) then you can use the right rear dial to set your shutter speed and the camera will set the aperture for you. To stop the action you will likely need at least 1/125 or 1/160 of a second. Go as high (fast) as you can--the limit will be your lens. The standard "kit" lenses are mostly F5.6 as the biggest aperture, and that is limiting without a flash or daylight. You might also try a monopod--a one-legged stand--to help steady your camera for you.
Dec 09, 2010 | Nikon D90 Digital Camera with 18-105mm...
Speedlight SB-600 TTL Flash: When I set my SB600 (mounted on D70) to TTL or TTL...
the sync speed for the sb-600 is onlt 1/200 on most cameras i think so if your shutter is faster then that then all you will see is black/ the curtans behind the shutter.
basicly just try again with a slower shutter speed
May 07, 2010 | Nikon Speedlight SB-600 TTL Flash
Hi! I just got an SB-900 flashlight to go with my
Personally, I'd go with Manual on the camera so as to have complete control over both aperture and shutter speed, and iTTL on the flash. Bear in mind that a single SB-900 isn't going to light up an entire basketball court or wherever you might be photographing. If the pics are too dark, it's most likely that the subjects are too far away.
If you take a picture of a chair in the middle of your living room, does that come out too dark?
Dec 28, 2009 | Nikon D60 Digital Camera
Please help! I have a nikon d80 with a 18-135 mm
Ask the players to run slower.
Seriously, there are limits. There's only so much light in the gym, you ISO only goes so high, and your lens is only so fast. A faster lens can get you a stop or two. You can try adding more light. Beyond that....
Dec 21, 2009 | Nikon D80 Digital Camera with 18-135mm...
Shutter is lagging with sb-800 flash attached. flash goes off, 3 sec later shutter goes
Have you checked the flash mode?
I have no problems with the combination D300 SB-800.
I assume you don't have a picture if the flash goes off before the shutter open(?)
If you do check the menu e2 Flash shutter speed you can set it at a few seconds in spite of the fact that the flash sync (e1) is something reasonable like 1/250
The flash shutter speed is set to 1/60 in my camera...
Aug 21, 2009 | Nikon D300 Digital Camera
SB flash does not synk with d90
Are you waiting for the flash to be ready before you fire the first photo?
What shutter speed are you using? Are you trying to sync at too high a shutter speed?
Jul 05, 2009 | Nikon Speedlight SB-600 TTL Flash
Sync speend
1/125 of a second, according to Nikon, but I've found on my N8008 that using 1/60 is more reliable.
if you use one of Nikon's dedicated Speedlights (SB-24, SB-23, SB-22, SB-20, SB-18, and SB-16B) then they set the synch speed automatically.
Jul 01, 2009 | Nikon N6006 35mm SLR Camera
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Blurry flash shots
    Try increasing your shutter speed (maybe 1/250)
    Sep 30, 2008 | Nikon D40x Digital Camera
    Nikon Speedlight SB-800 TTL Flash Logo
    157 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
