Question about Dewalt Heavy Duty 2 Brad Nailer Compressor Combo Kit
Air nailer - how do i stop large indentation from safety head?
  • David Ford
    David Ford May 11, 2010
    some different brands offer a rubber foot to prevent this give me the model and brand and I will see if they offer one for your tool
  • 23 Answers
Adjust your air pressure turn it down 10 lbs fire a few then repeat untill its set proper just remember different pressure for harder woods experiment on scrape wood till proper pressure is set
Posted on Jul 14, 2009
My dewalt dc 618c won't fire out nails when nailing doorstop heads. But I does nail the uprights??
Most nailers have a pressure sensitive safety feature surrounding or near the nailer head. This is so that they won't fire unless pressed against a surface. You may not be holding the nailer against the doorstop head board with enough force to release that safety.
Nov 05, 2014 | Air Tools & Compressors
Plunger extended and blowing air in framing nailer
Air leaking out of head and driver extended indicates that the cylinder seal is bad and or the head valve is sticking or stuck in the head. Easy to check by removing the head and looking at the large plastic seal on top of the cylinder. If seal looks good, pull out the head valve and lube with white grease. Parts are here :
Good luck
Jul 20, 2014 | Porter Cable FR350A Factory Reconditioned...
I put a new o ring rebuild kit in my Bostitch N80 sb framing nailer. I replaced every o-ring (including the trigger valve assembly
If the new trigger valve leaks air when you connect the air supply, most likely defective valve or air is leaking past outer trigger valve orings due to debris in the slot or new orings were cut when the valve was pushed in. If air leaks when you depress safety to fire gun then most likely problem is in the head valve or safety foot is not pushing the firing pin all the way in. Easy test, remove nails and remove the trigger to expose the firing pin. Connect air and very quickly depress the firing pin all the way in. If the gun fires, adjust the safety foot as needed. If the gun does not fire, remove the head and check headvalve orings for good snug fit against the cylinder within the head. The surface were orings make contact must be very smooth and not too deeply worn. If you notice fine scratches remove with fine sandpaper. Reinstall head using plenty of white grease on all the orings within the head and retest. Good luck
Feb 10, 2013 | Stanley Bostitch N80CB Coil Framing Nailer
I have an older gun can't read any specs the lables are worn off, the guns safety plunger is sticking allowing for free fire of the gun. most of my other guns have a step plunger with the spring r
To find the model number, look on ebay for hitachi framers and hopefully you will find one listed that looks like yours. If no joy, take the gun to your local fastener/nailgun dealer for parts. The dealer most likely has box full of used parts for your gun. I have seen many older nailers with bent safety foot that caused the plunger to stick in the engaged position. Some nailers have the safety return spring incorporated within the trigger plunger /valve area and still others that have the spring hidden under a guard on one side of the nailer (guard part # 883493). Look under the main body of the nailer for an indention where one side of the safety spring fits into (less than 1/2 inch in diameter) ; directly below the indention will be a point on the safety foot to catch the other side of the spring. Good luck
Oct 22, 2012 | Hitachi 3 - 1/2" Full Roundhead Framing...
The framing nailer blows air out the exhaust,and will not fire a nail when I pull tre trigger
take of clylinder head when off there is a large button make sure its fre should work like a door bell switch grease slightly and put together again
Aug 28, 2011 | Stanley Bostitch Coil Framing Nailer
Gun fires, leaves good indentation, no nail. WCE working properly, took head apart to look for jam but nothing in there and am using compatible nails. Also oiled it but no luck. Was working fine doing...
Remove nails and use thin tool to push driver all the way up to top of cylinder. If the gun fires one nail then skips, the driver is not returning to top of cylinder. If no nails fire, then nails are not feeding into proper position. Driver must return to top to allow nails to feed into position. Most common problems are bent driver, worn piston oring and bad batch of nails(head too large). Good luck
Jan 14, 2011 | Campbell Hausfeld 2-in 18 Gauge Brad...
When i push the trigger air is comming out but the gun is not shooting
make sure the safety release where the nail comes out is depressed. also check to see if it is low in nails/staples. I have an older nail gun that will stop when it is low on nails
Jan 13, 2010 | Grip Rite Grip - Rite 21 Round Head...
Gun does not fire every time
make sure the safety is being pushed in all the way
it will not fire unless the safety is fully engaged
Dec 12, 2009 | RTO PasLode 900420 Impulse Framing Nailer
I have a PC nailer (Finish) It is misfiring? was working fine. Now it does not NAIL although I can see the indentation on the wood ...help!!!!
Check the magazine area near the head for a jammed nail or other feed obstruction. It sounds like the driver is hitting the wood ok. Did you change nails (brand, type, or size) when this occurred? Make sure the magazine feed spring is ok.
Nov 12, 2009 | Porter Cable Cable No. FC350A Clipped Head...
I have a Paslode framing gun. When you connect the air hose, air comes out of the rear of the gun. What would cause this issue?
There is a large diaphram inside the nailer (inside) that is out of place or damaged.
Remove the 4 screws to access the diaphram and inspect it.
Oct 24, 2009 | NRS Paslode 501000 Powermaster Plus...
Dewalt Heavy Duty 2 Brad Nailer Compressor Combo Kit Logo
141 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
